Front main cap question
Old Feb 4, 2004 | 08:28 PM
jonaddis84's Avatar
I accidentally tossed the front main cap in the file13 when i got my new block (getting splayed caps). Is it a problem using a cap from another block, used whatever? Will obviously be getting a line hone anyway.
And if its no biggie, any of you engine builders have an extra LT1 front cap layin around?
Old Feb 4, 2004 | 08:34 PM
SStrokerAce's Avatar
Your best bet is to get an aftermarket billet one like the 3 middle ones.
The rear cap is pretty dam stong in stock condition and the front is a week point especially in a blown motor.
For $70 it's a good addition to the motor anyways.
Bret
Old Feb 4, 2004 | 08:36 PM
Lonnie Pavtis's Avatar
It may cost you a few extra $ to get the front cap fitted to your block (usually under 1/2 hr labor charge worst case), but otherwise you should be fine.
Old Feb 4, 2004 | 08:38 PM
jonaddis84's Avatar
Bret
I like that idea, but wasnt 100% sure the front was the same as the middle three.
One other question, well two, are all SBCs stepped like LT1s? and will ARP main studs cover the rear cap?
Old Feb 4, 2004 | 09:12 PM
Nah a front cap is usually a 2 bolt cap.
The studs will still work on all the mains.
Bret
Old Feb 4, 2004 | 09:14 PM
jonaddis84's Avatar
Bret
I mean how the face of the cap is stepped down as it gets close to the bearing. How like an inch out from the bearing it is ~1/16" lower.
Old Feb 4, 2004 | 09:15 PM
Yeah as Lonnie said that just takes a little work to fit in there correctly. It fits ALMOST exactly in the same place
Bret
Old Feb 4, 2004 | 09:18 PM
jonaddis84's Avatar
Gotchya, didnt think LT1s were specific there. Thanks fellas, will probably be ordering a billet one, might be overkill for mostly NA, but ohwell.
Old Feb 4, 2004 | 09:21 PM
Good excuse as any to me.
Bret
Old Feb 4, 2004 | 09:32 PM
jonaddis84's Avatar
Thats the excuse that gets me into trouble...oh crap, my piston just went through the cylinder wall....ohwell, stroker!
Old Feb 4, 2004 | 10:01 PM
rskrause's Avatar
Moderator
One other point: the rear steel caps are very expensive.
Rich Krause
Old Feb 4, 2004 | 10:05 PM
jonaddis84's Avatar
Rich Krause
Haha, damn good thing my brain didnt crap out long enough to throw that one away..
Old Feb 4, 2004 | 10:31 PM
Yep Rich is right again!
About 4 times as much as the front one, or about the same price as the front 4 caps together!
Bret
Old Feb 8, 2004 | 08:51 AM
racer7088's Avatar
Thumbs up
It won't be cheap you have to bore the new front cap to size and then line hone the block. More like 200.00 labor probably.
Old Feb 8, 2004 | 10:16 AM
jonaddis84's Avatar
Its getting all new billet splayed center caps, so that will need to be done no matter what.
