Formula for pushrod length?
Old Jan 17, 2004 | 12:46 AM
Gripenfelter's Avatar
For LT1s is there a general formula for how much shorter a pushrod should be if you are going with a higher ratio rocker and higher lift cam?
Like a 1.7 rocker on a .510/.525 lift (with 1.5s) cam?
Old Jan 17, 2004 | 08:31 AM
OldSStroker's Avatar
It depends on a couple of things: cam base circle diameter and rocker arm configuration and of course valve stem length. If you change heads that's another factor. If the cam is higher lift there's a good chance the base circle will be smaller, and you'll need a longer pushrod rather than shorter.
Of course, milling the heads, or decking the block shorten the required pushrod length.
Rather than try to calculate, it's probably better, and a lot easier to use an adjustable measuring pushrod to get the correct contact pattern on the valve. I'm not telling you anything new, just that measuring then buying the correct length is easier than trying to figure it out and having to buy and return a couple sets of pushrods.
Often Bret sends a cam/valvetrain customer all the valvetrain parts except pushrods, and includes a measuring pushrod. The customer installs everything, determines the correct length and sends back the measuring pushrod so that the correct length pushrods can be ordered and drop-shipped. It works out quite well.
Old Jan 17, 2004 | 08:34 AM
rskrause's Avatar
Moderator
It really needs to be measured. A back yard method (mine) is to have a bunch of old pushrods of known length to try. Otherwise, a measuring pushrod is the easiest way.
Rich Krause
Old Jan 17, 2004 | 08:05 PM
Where could I find an adjustable pushrod?
Old Jan 17, 2004 | 08:56 PM
Comp catalog page 293
http://compcams.com/Technical/Catalo...3/HTML/293.asp
Old Jan 17, 2004 | 10:55 PM
jonaddis84's Avatar
This might sound dumb to you guys, but how do you know even with a measuring rod how long it should be? I mean you could technically use different length pushrods, since you could just adjust the lash differently right, but that wouldnt be good, so how do you know what the exact length should be?
Old Jan 17, 2004 | 11:27 PM
rskrause's Avatar
Moderator
The Comp Cams catalog has a nice description of how to measure for PR length.
Rich Krause
Old Jan 18, 2004 | 03:00 PM
kmook's Avatar
Advanced Tech Moderator
http://compcams.com/Technical/Products/Pushrods/
Formula Steve
Sep 19, 2023 08:31 AM
13qtr
Oct 28, 2016 08:11 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
