Mustang TB on LT1?
Old Jan 17, 2004 | 09:00 PM
VIPRETR's Avatar
Question Mustang TB on LT1?
I'd like to use a Mustang TB on my Vic Jr. and I'm curious if anyone has ever wired one up using the stock ecm/wiring harness. If it comes down to it I guess I could use an LS1 TB but the Mustang stuff is so cheap I'd like to start there. It's for a 95 Formula. Thanks.
Old Jan 18, 2004 | 01:31 AM
AdioSS's Avatar
West South Central Moderator
Dang, I was hoping this thread would be about using an DOHC 2-barrel throttle body on an LT1-type intake.
Old Jan 18, 2004 | 08:54 AM
Hot Rod Hawk's Avatar
I belive a ford use's a 0~5v refferance and sensor ground would be same as would feed back to ecm. Just need to know what the pinout locations are for the ford sensor.
Ya tried a ford board yet for TPS pinout info?
Old Jan 18, 2004 | 01:19 PM
VIPRETR's Avatar
Thumbs up Ya tried a ford board yet for TPS pinout info?
Not yet, that is my next stop. Thanks for the info.
Old Jan 18, 2004 | 01:33 PM
NOMAD's Avatar
I think your going to have more trouble that what you think. Your IAC and your TPS readings would need to be taken from the GM sensor, even then, your going to have to work around the throttle connection.
-Shannon
Old Jan 18, 2004 | 03:53 PM
VIPRETR's Avatar
Nomad, that's why I'm hoping someone else has done the swap on an LT1. I did check out Wilson Manifolds website and it seems that they make TBs for LS1s. Never heard of anyone running one but if they can do one in a popular size like 90mm I'll probably go with that. I think FASTs new 90mm for the ls1 has some kind of odd bolt pattern or something? Thanks for the input guys.
Old Jan 18, 2004 | 05:54 PM
oil pan 4's Avatar
If I can put a LS1 tb on a V6 useing the V6 sensors and wiring you should beable to use a stag tb.
You will have to test the stag sencors on the tb and see if there the same as yours like the tps resistance, play with the IAC it might work it might not.
You have to get creative and be orignal.
ChrisFrez
Feb 1, 2015 08:26 AM
ChrisFrez
Jan 11, 2015 03:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
ChrisFrez
Dec 7, 2014 06:01 PM
NewsBot
Dec 3, 2014 12:30 PM
