fabricating longer runner LT1 intake manifold
Old Aug 4, 2006 | 01:57 PM
  #151
Denny McLain's Avatar
Re: fabricating longer runner LT1 intake manifold
Originally Posted by grammerman
50 ft. lbs at 3000 RPM's is not what I'd call a small gain when you can do it and still have a manifold that is optimized for high RPM peak power too. I believe the gains at part throttle are even more impressive as a percentage because the intake tract sees lots of vaccum. The charge inertia and resonance tuning combine to help cram much more air in there under light load. If you think there are too many things to go wrong then maybe you haven't fab'ed many projects of this complexity level. I have. You have to visualize everything down to the last detail and put it on paper, then the things inevitable things you didn't think of are generally manageable. Experience helps a lot here. I Already have a stroker crank going in so that suggestion is covered.
Being I’m the only one apparently on the list who actually owns an intake manifold with six inch runners, may be able to transfer how the car responded going from a very heavily welded and reported/raised port LT4 intake:
True it picked up 47ft lbs of torque 3000 rpm but the throttle response is also much quicker. There was an off idle hesitation that has completely cleared itself up. After programming it usually takes at least a couple of tanks of gas for the computer to relearn how to idle. With this intake it cleared up perfectly after about a half a tank of gas.
The car also seems to run smoother overall and for sure you feel the extra torque especially in the higher gears. Say for example a light turn yellow and I’m cruising in 4th gear @ 35mph. Very surprised how much quicker the car picks up speed in higher gears and lower rpm. Do I notice it in first gear? Na….spun the tires before and spins them now.
As far as the loss above 6100 goes: After a couple of months of internalizing and looking at the dyno sheets, the intake did exactly what you would expect a more efficient intake with longer intake runners would do. Shift peak power downward and increase low end.
It did that all right greatly adding power in the lower range. All I need to do now is correct the powerband with the proper cam so that it peaks in the 66-6800 rpm range. and I’m positive the bottom end will be stronger than before and it will also pick up on top because the manifold overall is more efficient. Just a matter of adjusting to the overall change in powerband.
Think you’ll see the car close (if not making over 500 rwhp) in the next couple of months and I’m not sure how many people can say that from a standard 23 degree head, hydraulic cam LTX car.
Would I do it again?............Damn right. Now those expensive stepped headers with reducer merge collectors?? Not so sure about that one.
Old Aug 4, 2006 | 02:06 PM
  #152
383TransAm's Avatar
Pics?
Old Aug 4, 2006 | 02:13 PM
  #153
grammerman's Avatar
Hey Denny, that is a great post. Very good information man, very much appreciated. Now according to the Chrysler patent on ram tuning intake runners from way back when your 6" runners plus about 6" of intake port to the valve head should produce a peak centered around about 7000 RPM's. I've seen quite a few dynos on various tuned runner intakes and the Chrysler formula ( 84000 divided by runner length from plenum to the head of the valve equals peak RPM point) is usually in the ballpark. Did you enlarge the cross sectional area of the LT1 manifold? It might take a little more CSA to really let the 6" runner produce full peak HP potential on a hot smallblock though at the loss of some low/mid and throttle response.
The Viper engine uses a pair of single butterfly throttlebodies ( or at least the one I did an engine conversion with did anyway). If I remember right they use a crossover cable to actuate the second one and sync it with the primary that the throttle cable connects to. Usually when I'm working on something this complicated I spend a LOT of time on paper. You need accurate dimensions on your space you have to work with and then detail everything with center to center dimensions, angles, ID, OD, height, width, length and any other dimension you can think of, helps to use a graphics program and do everthing to scale. You need to work out all the details so they appear to work in side views, top views and end views. Even after all that you just can't hardly think of everything but it sure beats hacking the same parts off five times to try to make things work.
Later, Michael
Old Aug 4, 2006 | 04:03 PM
  #154
Originally Posted by 383TransAm
Pics?
There are some picturers of the intake way earlier in this string. Can't believe how long this thing got.
Old Aug 4, 2006 | 04:12 PM
  #155
Later, Michael
The cross sectional is a bit larger (wider) than a LT4 raised port off road gasket. I gasket matched it to this gasket (same as the heads) and had to do some epoxy fill blending about a couple of inches just before it reaches the heads. Didn't bother to measure but I'd guess about .200 inch of taper. Have picturers but not sure if the detail is enough for anyone to tell.
Again, still playing with the combo and it's been so frickin hot here in Dallas that the first cam I'm going to try is still sitting in the box in the car. If it every gets below a 100, just might give it a shot and see what it does. It will get worked out but when you don't have a known variables to work with your the test monkey shot off into space.
Old Aug 4, 2006 | 05:02 PM
  #156
jerminator96's Avatar
Well after doing some calculations, I just don't think I can get my design to work with the rectangle ports and my given amount of space. I maybe could get it to work with oval ports but the transition wouldn't be great for airflow.
However, the VH45 heads that I may purchase for my DOHC SBC project have concentric circular intake ports, a prime candidate for this design.
Old Aug 6, 2006 | 09:13 AM
  #157
383TransAm's Avatar
Denny dose that intake run flat all the way accross the bottom?
Old Aug 6, 2006 | 09:53 AM
  #158
CSJTA's Avatar
I like to hear the story on the exhaust vacuum bungs to the valve cover
Originally Posted by Denny McLain
Let's say it was a $2,000.00 lesson on diving into the pool w/o checking how deep the water is taking someone's word on it. We picked up nothing. Yep, CNC ports, 1 3/4th to 1 7/8th to a 3" Burns style merge collector with 2 1/2 reducer. And the dyno said zippo!
Haven't given up completely on the headers as couple hardcore racers I know say they are the real deal but the cam needs to be changed to get the most out of the headers.
Already got a couple of cams that we'll try and still doing some research but everything is on hold till the weather gets better. It was 107 here in Dallas with everyday over 100 degrees and orange polution alerts. Not exactly home run tuning weather.
Now you should hear the story about the exhaust vacuum bungs and hooking them up to the valve covers.
Old Aug 6, 2006 | 11:41 AM
  #159
383TransAm's Avatar
Old Aug 7, 2006 | 01:04 PM
  #160
The intake is flat on the bottom. Actually thought of having it thermo coated but ended up not doing it.
Did those the same time as the intake hoping to pick up a little more power through better ring sealing and should have waited to do it separately. Don't have a baseline to make any intelligent comments. The guys using vacuum pumps claim they pick up 10-15 hp on top but I have doubts that much is really going on. Should be some vacuum caused by venturi effect but I need to play with that a little to see if it drawing much at all.
Kinda like the expensive headers........good idea at the time. Haven't completely given up on the headers as someone told me you needed to change the cam split to take advantage of them but I haven't been able to substantiate that either.
Again, ya ain't gonna make any yards if ya don't carry the ball. Just trying to do my best at figuring out this stuff.
Old Aug 7, 2006 | 01:55 PM
  #161
You seems to be doing a good job of that. The rest of us (with less money) will let you do all the expensive research Just tell us how it works out.
Jeremy
Old Aug 7, 2006 | 04:14 PM
  #162
Jeremy
I've got the guts........somehow I seem to be missing the glory. It would be nice to hit a couple good ***** instead of clobering dirt.
Old Aug 7, 2006 | 04:35 PM
  #163
Hey I'll be right there with you if this DOHC project gets off the ground. Then maybe we can trade secrets that don't work in hopes of success on a different motor.
Jeremy
Old Aug 8, 2006 | 02:38 PM
  #164
95 Z/28 LT1's Avatar
Super Moderator
If any of you have personal problems with each other here I'd appreciate it if you took it to PMs or better yet, to email.
I don't want to have to say this again in this thread, thanks.
Old Aug 8, 2006 | 04:52 PM
  #165
grammerman's Avatar
Hey Mr. Moderator, while your at it I'd appreciate it if you'd delete the posts that have polluted this thread with arguments that have nothing to do with the topic. Can't hurt to ask, can it?
