Engine Swap Questions
Old Sep 16, 2004 | 09:49 AM
hemigtx001's Avatar
Im swapping my v6 and trans from my 1993 firebird, with a Small Block 350 Carb'ed with a turbo350 trans. i was told quite a few people here have done this swap. i need to know what to expect. and was wondering the dificulty on this swap. and tim restraints. and what i sneeded for this swap. and i have a few questions. So if you have doen this swap before. Post up.
Or at least have done a simular swap.
Old Sep 16, 2004 | 03:36 PM
Re: Engine Swap Questions
You would probably have a better chance of finding someone who has done the swap on "V6 Tech".
Old Sep 17, 2004 | 02:10 AM
Highlander's Avatar
My guess is and a rough idea:
K-member and Mounts. It should be a direct bolt in after that and the rest of the things you want to add there.. but with that everything else comes to place...
ahh... and be prepared to cut the cowl in order to have the opening of the carb fit... seen a few pictures..
rocketman051894
Jan 30, 2015 03:23 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 12, 2014 10:51 PM
squirrels
Jul 13, 2002 01:58 AM
