Engine balance ?s
Old Feb 10, 2004 | 03:55 PM
CRAZ81's Avatar
Unhappy Engine balance ?s
I recently re-built my 350 in my Blazer. I had it all balanced. There was a problem with the rear main seal so crank, cam and all of the bearings got ruined after only 10 miles. My question is when I get my new crank do I need to rebalance the whole rotating assembly or can I get away with just rebalancing the crank?
Old Feb 10, 2004 | 04:35 PM
MaxRaceSoftware's Avatar
which ever Shop did your engine balancing before...should have your balance record on computer or index card
you should get a price break..because all they have to do is balance the crank...from your original Bobweights
you paid already for them to establish your Bobweights
so it should require less time/effort to balance your crank to that Bobweight as long as 2 cranks are identical in manufacturer/alloy/application
HectorM52
Jul 30, 2017 11:46 AM
Jason Short
Jan 19, 2015 06:33 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
Nostang 96z
Sep 15, 2002 10:15 PM
