Egr
Old Apr 20, 2003 | 12:34 AM
Mir Hussain's Avatar
Arrow Egr
What I been told is LT4 and LS6 and later dont have EGR. They over come with CAM over laps.
My Question is How they do that.
I have 96TA. I am thinking of making Custum CAM to a LS6 02 cam specs. How that would work my LT1. I want sleeper like LS6 02 is. I also want Emission and Drivablility to be normal.
What I am looking into it
Can it be done ?
Sorry If its not for Advance Tech!
Old Apr 20, 2003 | 08:10 AM
Josh-'04 GTO's Avatar
The LS6 makes it's power because of great head flow among other things. Just because you grind the same cam does not mean you will have a "sleeper". Your cam should be based off the lift where your heads flow best and the intended RPM range.
Old Apr 20, 2003 | 09:56 AM
If you want drivability, legal emissions and *****-out performance, why not just leave the LT1 EGR where it is, and functioning. EGR only operates at part load condition, and actually reduces the chance of detonation when you are lugging the engine at lower RPM. It does not operate at all at WOT, so it has no possible effect on performance, as long as it is closing properly.
The "no EGR because of overlap" of the LT4 and LS6 was arrived at through extensive emission testing on a dyno. I would think that it is a combination of many factors, including the exhaust reversion that takes place at a particular RPM and valve position, and that is a function not only of the cam grind, but of the intake and exhaust path configurations. Grinding a cam the same as one in some totally different configuration isn't going to guarantee similar results.
Old Apr 20, 2003 | 10:20 AM
So what you suggest ?
Should I get Stage Heads ?
or you have some cam in your mind ?
Old Apr 20, 2003 | 10:26 AM
BINGO That is what I want. My prob is my car is 96. I have Headers and ORY. WHich mean very free flow exhaust. Thus make EGR not work and kick in P0400 Code. Tell me How I can resolve this problem. ?
Its I really dont mind EGR. I kinda like ite their reduce emission at no performance cast; I am all for it.
See I have 96 LT1. Very close to LT4. What I can do achive what LT4 had. Or Question should even is do-able thing ?
Old Apr 20, 2003 | 10:50 AM
If you want emissions legal, why do you have an off road pipe? I would probably try a cam with a little more overlap, such as the LT4 Hot Cam. Little bigger but will still pass emissions with a tune.
Old Apr 20, 2003 | 11:04 AM
I was wondering I could done that ?
SNiff test
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jlo
Jul 29, 2015 03:52 PM
