Drilling for distributor
Old May 26, 2004 | 01:52 AM
  #31
Steve in Seattle's Avatar
Originally posted by sleeperz28
Yeah it has to go back to be miled another 3/8". They said they set it up for a std 9" deck. Not sure if the LT1's are a little higher or if my AFR heads are giving it a little height. Anyway another $40 in shipping. I just hope I can get everything done and running for the power tour!
It might be the AFR's. I've heard a few people mention this issue with the intake not seating all the way down on some AFR castings... can't remember the details though.
Old May 26, 2004 | 01:55 AM
  #32
On a side note, I've considered drilling/tapping a plug over the oil pump idler in a similar way... although my lazy butt gave up on the idea and just decided to get an accumulator instead.
Old May 26, 2004 | 10:24 AM
  #33
sleeperz28's Avatar
Hogan set my distributor up for a standard 9" deck height. Everything lines up perfect on my car, intake to heads, distributor to intake, but my deck height seems to be a little higher then normal. The piece of aluminum they welded on has to be cut 3/8" so I can move that collar down to get a clamp on there. The end result will be, kind of what chris said, 1/4" high collar welded to the intake for the mating of the distributor. Roughly anything higher will not work.
Yeah I will agree that oil pump driveshaft is a PITA to line up!
Old Jun 5, 2004 | 07:33 AM
  #34
sleeperz28's Avatar
Everything is done and working! I must say the car has never ran better! The first thing I noticed is there is no longer un-burnt fuel running through the exhaust, which in the past caused a poping noise on the decel. Cruising through the gears the motor revs very smooth. It almost feels like the motor went through a overhaul and things were changed such as the cam.
Obviously out of the three ignition setups that I had this is the best. If you have an aftermarket computer and are able to perform this mod I wouldn't think twice.
Old Jun 6, 2004 | 08:08 PM
  #35
96Z28SS's Avatar
I have been trying to tell people that.
The distributor mod and aftermarket computer is the way to go with these cars.
68camaroboltz
Oct 5, 2015 01:46 PM
autoxr166
Sep 25, 2015 04:21 PM
FryedClutch
Sep 1, 2015 08:24 AM
realistyc
Jul 28, 2015 07:32 PM
gonzo275rltw
Jul 11, 2015 04:19 AM
