does oil pump need a gasket?
Old May 24, 2004 | 05:09 PM
shocker45's Avatar
hey, were building a 383 stroker right now. our oil pump didn;t come with a gasket. do we need to use one or do we just leave it metal to metal?
would silicone be okay?
Old May 24, 2004 | 05:20 PM
AdioSS's Avatar
West South Central Moderator
I still don't believe it, but no gasket needed there.
Old May 25, 2004 | 09:59 PM
Lonnie Pavtis's Avatar
Between the main cap & pump.... no. They do come in some kits though. If used & it did split or partially blow out, it would result in a substantial leak/pressure loss.
The 2 (cap/pump) machined surfaces are not a major source of leakage & nothing to worry about. It would be better to have a small leak between a gap of less under .001" instead of having a chunk blow out of a 1/16" thick gasket.
I have also seen a gasket for the oil pump cover.... do not use this either. It will increase the pump clearances (between gears & end cover) & result in lower oil pressure by creating an internal pump leak.
Old May 30, 2004 | 03:25 PM
97 RedSS's Avatar
Didnt use anything on my motor and no leaky here..
Cody
Old Jun 1, 2004 | 10:18 PM
Red96Lt1's Avatar
Nothing on mine. I'm ok.
Old Jun 10, 2004 | 10:50 PM
mehoffz24's Avatar
i heard that it is bad to take an oil pump apart and spin the gears in there, is this true, what could potentially happen? they are balanced right.
Old Jun 12, 2004 | 03:00 PM
FormulaLT-1's Avatar
ttt
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
