Do I need to rebalance?
Old Feb 26, 2005 | 07:14 PM
Nitromethane's Avatar
Hey guys. haven't posted in a while, but converting my 383 nitrous motor to a turbo motor project which means new pistons - my current flat top's weigh around 415g (according to the manufacturer) - my JE turbo pistons weigh "430g" (in actuality they are around 428/429g after weighing them myself) - someone told me that if the new pistons are within 5% of the weight of the old pistons, I don't "NEED" to balance the motor, is this true? I know I SHOULD rebalance - but if I'm not gonna notice any vibrations and there's gonna be no damage to the motor if I don't rebalance, I'd rather just put the new pistons in and get on with life. I'm willing to sacrifice a few hp.
So you guys with the machining experience, should I re-balance over a <15g weight difference?
Old Feb 26, 2005 | 08:33 PM
chevyguy3's Avatar
Re: Do I need to rebalance?
i wouldnt worry about it. normal carbon buildup and oil can add up to that much of a difference in weight (though some builders will account for that and take a guess at adding wieght for those factors when balancing)
personally though if it was my motor, i would get a good scale and grind your new pistons to the weight of the old ones (or as close as you can get if there isnt much material to play with)
PaNaRaMuH
Jan 27, 2013 10:53 PM
detroitlt1
Jun 21, 2011 05:30 AM
blown94
Feb 9, 2009 07:38 PM
RallyBoy1
Oct 24, 2008 06:38 PM
TransAm-Z
Advanced Tech
Jul 12, 2005 10:04 PM
