Distributor gear
Old Jul 13, 2005 | 11:32 PM
zrs's Avatar
zrs
Distributor gear
I swapped out the stock 305 engine from my RS Camaro. My question is do I need to change the distributor gear since I am using an LT-4 Hot Cam? The 305 engine was a roller block.
Old Jul 14, 2005 | 11:52 AM
rskrause's Avatar
Moderator
Re: Distributor gear
If it had a roller cam in there before there would be no reason to change the gear (if it is in good shape).
Rich
Old Jul 14, 2005 | 05:01 PM
SStrokerAce's Avatar
The HotCam is a cast core anyways so even if you had a flat tappet the distributor gear will be the same.
Bret
REDNECKISBOSS
Mar 22, 2015 08:31 AM
brentbrowning01
Dec 3, 2014 10:36 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
ScottZ
Mar 3, 2004 01:34 PM
