Decking a block?
Old Jul 23, 2005 | 03:52 AM
  #31
TheNovaMan's Avatar
Re: Decking a block?
Originally Posted by atljar
We have a block mill with a CBN bit in it. Basically the mains sit on a bar and then its tightened down through the cam bore. and then level it all off.
Random Questions...
If you assemble a block and find you need .005 for 0 deck, I guess you could rub off the machine and cut your .005. What happens if the core has shifted and you have .005 in number 8 and .001 in number 2? Do you cut the block at an angle?
It sounds to me like that type of machine is designed automatically to mill the decks parallel with the crank centerline and at 45° to the cam-to-crank plane. It doesn't sound like the machine knows or cares if the decks are crooked to start with; they'll be true when it's done. But somehow that also sounds too good to be true.
Old Jul 23, 2005 | 12:20 PM
  #32
MachinistOne's Avatar
That's how most decking machines are...the front to back level and square will be as acurate as the person who originally leveled the machine, but the level from side to side(bank to bank) has to be set by the operator.
GREEN3112
Feb 10, 2019 09:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
heus
Sep 8, 2015 12:01 PM
