David Vizard Cam Selection Program
Old Mar 18, 2004 | 08:39 PM
Twelvz's Avatar
Question David Vizard Cam Selection Program
http://www.davidvizard.com/camshaft.html
Has anyone used this program?
Want to know what experiences people have had before and after or just the results of the CamMaster program
Old Mar 19, 2004 | 05:31 PM
SStrokerAce's Avatar
I've seen some cam choices from it and it seems pretty basic in some reguards. It will get you close, but you can do better.
Bret
Old Mar 21, 2004 | 01:49 AM
OneFlyn95z28's Avatar
What he said.
I have also heard of cams being sent out that were not speced as they should
Old Mar 23, 2004 | 10:21 AM
stealthramman's Avatar
I read an interesting article about a 351 windsor ford with an h.r. cam spec'ed from this cam master program. The engine and cam combo was mild but the engine made over 500 hp, with some big torque numbers also. They gave the cam select program alot of credit for the good output of the motor.
Old Mar 23, 2004 | 04:19 PM
SS MPSTR's Avatar
Originally posted by stealthramman
I read an interesting article about a 351 windsor ford with an h.r. cam spec'ed from this cam master program. They gave the cam select program alot of credit for the good output of the motor.
Nothing against David, but I'd never expect negative or unsatisfactory reviews within 'sponsored' articles.
Old Mar 23, 2004 | 04:23 PM
I've not run a cam from the cam master program, but David Vizard is a well known engineer and designer and is very well respected in the industry. There must be something to it, coming from this guy.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jan 23, 2015 01:13 PM
Dec 17, 2014 11:00 AM
