Custom wiring question
Old Mar 25, 2008 | 08:27 AM
woody80z28's Avatar
I have an 80 Z28 that I swapped a LT1-style T56 into along with the console, ebrake and seats, etc. from a 93-96 interior. I'm rewiring the whole car right now and have not been able to figure out how to wire the ebrake lever switch for a warning light when it is engaged with the ignition on.
As best I can guess, If I give the bulb a switched ign source and run the ground wire through the switch the light will function opposite from the way I need.
Anyone know how to rig it?
Old Mar 25, 2008 | 09:34 AM
ulakovic22's Avatar
I'm no wiring expert, but I think if you run switched to the light and then ground to the ebrake you should be good to go. When the ebrake is up it completes the circuit and you get a light and when it's down it's open and no light.
Old Mar 25, 2008 | 10:06 AM
woody80z28's Avatar
I can give that a try. From the look of the switch I thought it was opposite than that.
Old Mar 25, 2008 | 09:36 PM
woody80z28's Avatar
I'm an idiot. Worked perfect. Once I pulled everything apart and took a look you're right. Supply a hot to the bulb and the switch grounds it when the lever is up.
Old Mar 25, 2008 | 09:55 PM
ulakovic22's Avatar
Glad I could help
Noenav
Mar 1, 2019 07:38 AM
CARiD
Jan 14, 2015 04:00 AM
cmdeshon
Dec 12, 2014 10:51 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
