Crankshaft
Old Dec 26, 2003 | 09:56 PM
94TA_LT1's Avatar
Crankshaft
Anybody know if a LT1 crank will fit in a 96 chevy vortec 350 truck motor
Old Dec 27, 2003 | 04:20 AM
SStrokerAce's Avatar
yes, both a 1 piece rear main seal cranks. Just make sure you check the balance on them.
Bret
Old Dec 27, 2003 | 05:39 PM
94TA_LT1's Avatar
what do you mean by check the balance? the balance of the crank?
Old Dec 27, 2003 | 11:38 PM
94TA_LT1's Avatar
Anybody else know what he was talking about?
Old Dec 28, 2003 | 11:19 AM
Turbo6's Avatar
The crank balance has to be checked...ie, if the crank is externally balanced in the rear by using a weighted flexplate/flywheel (as they come from the factory), either you have to balance it using a counterweighted flywheel/flexplate or internally balance the rotating assembly and then match it with a neutral balance flexplate/flywheel. Though, if you are going to be building a whole new rotating assembly w/ fresh pistons/rods it will need to be balance anyway, so just make sure you have the correct flywheel balance to match.
Slayer
Aug 17, 2015 03:55 PM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
mrwz28
Jul 8, 2015 09:11 PM
SergheiS
Jul 5, 2015 03:27 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
