cracking roller rocker nuts ???
Old May 26, 2004 | 03:27 PM
bowtiepwr's Avatar
Question cracking roller rocker nuts ???
>has anyone here split (cracked) an adjusting nut for the roller rockers ?
I have the Comp Cams 1.6 Pro Magnums for the 7/16 stud and noticed that one of the nuts was cracked staight down the side .
what could have caused this ?
Old May 26, 2004 | 04:45 PM
dave96dcm's Avatar
Mabye you tightened the set-screw too much.
Old May 26, 2004 | 06:07 PM
cnorton's Avatar
If the set screw is contacting the top of the stud too far down in the body of the locking nut, it may split the side of the unit. If this is the case in your situation, you may wish to consider installing longer rocker studs so that the contact point is higher, within the thicker, hex portion of the nut.
94Form
Jul 17, 2015 10:56 PM
gelbza
Jul 12, 2015 08:10 AM
Jul 10, 2015 02:23 PM
mrwz28
Jul 8, 2015 09:11 PM
