Compression and Milling Heads
Old Apr 23, 2003 | 11:09 PM
SVT Killer LV's Avatar
I just cammed my car. The heads are out being ported right now. Also they are out to be milled as well. I was planning on running the Felpro Head Gasket. How much will get me to 11.1~11.2:1 also I am not going to have valve clearance with that will I. I don't think so. But Lemme know.
TIA
Old Apr 24, 2003 | 02:05 AM
allmotorta's Avatar
The felpro gaskets are .039, correct? Assuming a stock bottom end, you need to get your combustion chamber to around 55cc's to achieve a compression of 11.2:1. So however much milling it takes to get to a 55cc combustion chamber is your answer...I'll leave that one up to the "real" advanced tech people
http://www.rosspistons.com/CR%20Calculator.htm
Old Apr 24, 2003 | 03:28 AM
SStrokerAce's Avatar
With a stock bottom end don't waste your time with the Fel Pro's at that thickness. Get the Imppy gaskets at around .021 and you will get a little more compression but much better quench which will allow you to run more compression.
The cam will tell you part of the P/V clearance tale.
Use that calculator at Ross's site. The stock LT1 pistons are about -5cc dish. If I remeber right, but I might not have.
Bret
Old Apr 24, 2003 | 08:27 AM
I will be running a CC306 with some well ported heads..
Old Apr 24, 2003 | 12:51 PM
I was planning a 15~20 mill on the heads... I need to call the guy today... please let me know.. thanks...
Old Apr 24, 2003 | 06:37 PM
Josh-'04 GTO's Avatar
I believe you remove 1-1.5 cc of combustion chamber for each .010" you mill off the heads. Hopefully that will help you plug in the correct numbers into the calculator.
Victor Lamb
Aug 26, 2017 02:52 PM
pimpss96
Feb 12, 2015 01:28 PM
Red_94Formula
Jan 22, 2015 12:17 AM
95chwagon
Jan 13, 2015 09:19 PM
