compression
Old Dec 16, 2005 | 10:57 PM
billyburnout's Avatar
compression
What is the highest compression that anyone is running on pump gas with aluminium heads. Im taking out my 9.5 slugs and want to go with 11.0, but I hear mixed opinions about what will work.
Old Dec 16, 2005 | 11:37 PM
bdc95ta's Avatar
Re: compression
their's a guy here in h-town running like 12.3 Static
-brandon
Old Dec 17, 2005 | 01:35 AM
jimbob65's Avatar
Re: compression
I'll answer this before it gets moved....
I run 12.48 to 1...It's not the SCR that gets ya, it's the DCR....Mine is only 8.77....Many here have run 9 to 1 but you have to get everything right on for it...Heck, mine was hard enough to tune...and goes into hard detonation a lot easier than before...After lots of tuning it's all good....
Old Dec 17, 2005 | 03:05 AM
1racerdude's Avatar
Re: compression
Are ya running an LT1 with reverse flow cooling?
Jimbob
Get ya some good cooling and it will do better. There are people running 9.6 an pump gas but I will stay at 9.1 'cause that's the way it came out. My static is 13/1.
Old Dec 17, 2005 | 09:13 AM
jimbob65's Avatar
Re: compression
Originally Posted by 1racerdude
Jimbob
Well, if I used my theoretical .006 ABDC (using intake duration and ICL), I would be right at 9.18 to 1 (74.5*ABDC). I checked my actual ABDC and came up with 79*. Several times...on two different lobes....Makes sense, because I got a base duration of 295 instead of 289 listed on lobe chart The exhaust lobes were right on the money so, I did have two control lobes....Moral of the story.....our DCR's may not be as high as we think...
Old Dec 17, 2005 | 11:51 AM
Re: compression
Jimbob
I'm running this in my 540.
Old Dec 17, 2005 | 12:53 PM
1racerdude's Avatar
Re: compression
It is the same rule of thumb.
Old Dec 17, 2005 | 09:00 PM
respectirocz's Avatar
Re: compression
i'm guessing scr and dcr stand for
static compression ratio and dynamic compression ratio
and i'm guessing static means the compression ratio calculated from total combustion chamber volume at bottom dead center to total combustion chamber volume at top dead center
what is dcr? and how is it calculated?
Old Dec 19, 2005 | 11:53 AM
383Z4ME's Avatar
Re: compression
http://members.uia.net/pkelley2/DynamicCR.html
Good write-up!
Old Dec 19, 2005 | 01:22 PM
1racerdude's Avatar
Re: compression
If it isn't reverse flow cooled ya better stick to 8.5DCR or ya may have to run fuel in it.
Old Dec 19, 2005 | 02:38 PM
SStrokerAce's Avatar
Re: compression
Problem is how you get there... usually high compression big blocks take some dome to get, and that can cause issues on a pump gas high DCR motor.
The other side of this is how much VE can you make, the more you make the less compression you can run. Hell the less compression you need, everyone seems to think a Pro Stock motor is running some crazy SCR, but it's really around 15:1.
Bret
Old Dec 19, 2005 | 02:50 PM
Re: compression
Originally Posted by 383Z4ME
Old Dec 19, 2005 | 02:52 PM
1racerdude's Avatar
Re: compression
If the dome is built right and has a fire slot it will be fine. Shouldn't take THAT big of a dome to get a 8.5DCR with a 75*IVC. Ya can always buy a small CC chamber head.
Hey: 15 to 1 will get it done...
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
pimpss96
Feb 12, 2015 01:28 PM
