Can you figure out at what intk. plenum size a motor will be choked at?
Originally posted by MaxRaceSoftware
Another dyno that seems to work very well is the Land & Sea Dynometer
i have a good friend that has one for Jr Dragsters and GoCart racing
some people say you can't measure down to 1 or so HP accurately on engines, but the Land & Sea model he has
seems to be able to accurately measure 1/4 to 1/2 HP accuracy
i've plugged in his data into my program and it correlates very well
even correlates very well with Comet Torque-A-Verter claims of 3.25:1 Torque Multiplication
the range i come up with is 3.00:1 to 3.70:1 TQMLT
from plugging his data
he got the Jr Dragster to go 7.80's at 74.5 mph 660 Feet
with 24.0 HP @ 8200 325.0 Lbs 6.13 gear ratio 18.5*8 to 19.0*8 tires
has SF FlowBench also, but abandoned Jr Dragster efforts when officials put a LIMIT on how fast you could run with Jr Dragster
now running Go Carts at Dirt Tracks
Remember when Jr. Dragster started? I don't think NHRA had any idea they would get to the performance level they have. Half that was about it. It's amazing what development time and money can do. Well, no it's not!
in fairness to Stuska/Depac/Starr
and
DTS Dynometers
at the times i compared readings ,
i think both Dynos were only capable of no more than 450 Rpm/Sec rates (?? not sure)
....things might be different now ??
a slower Rpm/Sec Test rate will show more HP/TQ
than a 600 Rpm/Sec Test
and
DTS Dynometers
. If not, they're two peas in a pod.
its Russ
but Russell Stockwell and his daughter = Ann
8.76 ET was their best until the LIMIT
Russell was really mad about the LIMIT
quit that same month
Correction to previous Post => it was 8.76 ET and not 7.76 ET
its Russ
its Russ
If your buddy knows a lot about the Briggs type engines, he probably knows Russ Bailey. His company is called Billet Specialties, and he used to make pistons, rods, heads, carbs (or maybe they were mfi?), head straps, etc. Prior to that he built chassis for dragsters.
i'm sure Russell knows and used parts from Russ Bailey
Stockwell had the Briggs engine up to 32.0 HP on his dyno and was going to replace the 8.76 ET 24.0 HP engine with the 32.0 HP ..should have made a HUGE ET/MPH gain
but NHRA put the clamps on that
He quit , and started dominating local Go Kart dirt track racing around my area
the last time i was at Dirt Track race his cars cam in 1,2,3
and i'm "NOT" the guy with camshaft design program
i've seen a Website a year or so ago referring to what you are talking about, but can't remember name of site
i think it had something to do with David Vizard
Originally posted by LTOne4Fun
SO how would i go about shooting for a starting point for runner length in a SBC with 350-400 inch motor, bout 6600-7100 rpm limit? Just to start testign with
6600 RPM = 14.9 Total Induction Length
7100 RPM = 13.8 Total Induction Length
Total Induction Length = from 45 deg seat angle -to- point where intake runner begins in the Plenum
use Scotch 1/4" wide masking tape
and carefully stick tape to 45 seat angle extending along roof , around valve guide to port entrance on cyl head
mark lines at each place
take tape out ..and lay flat and straight on table ..take dial caliper and measure between those 2 points
do same for Floor
Example=>
Floor = 4.000
Roof = 6.000
Total = 10.000
Mid-Port Length = 5.000 (10 / 2)
So Cylinder Head's Mid-Port Length is = 5.000 inches
then find Intake Manifold's mid port length
Ex= 5.000
so Total Induction Length = 5 + 5 = 10.000 inches
Another Port Example =>
Old # 292 Turbo heads -VS- old # 034 cast-iron Bowtie heads
Both have same physical outside looking dimensions
but internal mid port lenghts are different
Example=> 200.0 CC # 292 turbo
200.0 CC # 034 Bowtie
they look like same, but in reality the # 292 Turbo is
9 CC larger if actual mid-port lenghts were adjusted to same lengths
the #292 Turbo at 200 cc would have a much LARGER actual cross-sectional area than the 200 cc Bowtie
do same for Floor
Example=>
Floor = 4.000
Roof = 6.000
Total = 10.000
Ex= 5.000
Originally posted by OneFlyn95z28
so are we going to cover the original question much? I was kind of waiting to see how it came out...as I am hacking and welding on one of my LT1 intakes..
http://holley.com/HiOctn/ProdLine/Pr...MSM/7540P.html
The short runners of the LT manifold seems to me to be the bigger problem for NA applications.
ChrisFrez
Feb 15, 2015 07:49 AM
