Can you figure out at what intk. plenum size a motor will be choked at?
I figure you can rough guess at cfm requirements of a motor, but there should be a mathematical way of figuring when the volume of the intake plenum on an motor woudl become partly a restriction itself right?
Dont Pro Stock guys play with plenum volume itself alot, along with runner length size shapeetc
you can get close with equations
its best to dyno and track test plenum volumes
keeping the plenum volume to the least it can be without a significant Torque/HP Loss in the required/desired RPM range
will be a very good baseline to start with
then track test from that point on
i've seen where dragster starts to make 170+ mph
down dragstrip with a real good HoodScoop
allow you to run a little more plenum volume than the dyno would show you was correct
Troy Coughlin (Jegs) Pro Stocker
used my dyno for 6 weeks in 1994 July to August
we played a bunch with plenum volumes and runner lengths
its 10 years ago so i don't think it matters if i post some of data
total induction length 10 years ago was 11.68 to 11.72
average cylinder head mid-port length was = 6.680"
the plenum volumes are still relevant , so can't post this info
My guess is that they use variable inlet length and plenum volume for various rpm/vehicle speed combinations.
I understand Ferrari, where money is NO problem, have an engine dyno UNDER a wind tunnel so they can poke the air inlet box up into the airstream, which I assume is controllable for speed, for very accurate dyno testing. You're probably not there yet, Larry. Right?
i wish i was
you can easily pickup 20+ Torque with just 1.000" inch in the intake manifold runner on V8
i wish i was
Isn't that about the difference in a SBC Super Vic vs. a Vic Jr.?
about 1/2" difference in runners (reg SuperVictor vs Victor Jr)
but the SuperVictor has dividers coming into plenum too far at roof and topend HP suffers until you correct this..you leave middle of runner to floor part alone for length
effect of 1.500" inch change in intake manifold runner length BBC
RPM---TQ-------HP---------TQ--------HP with 1.500"inc
6900--717.6---942.8-----775.8---1019.2
7000--732.1---975.8-----763.0---1016.9
7100--729.8---986.6-----766.3---1035.9
7200--727.4---997.2-----765.2---1049.0
7300--733.8---1019.9----754.6---1048.9
7400--724.3--1020.5-----749.6--1056.2
7500--719.3---1027.2-----757.0---1081.0
7600--720.0---1041.9-----757.1---1095.6
7700--708.5--1038.7-----734.9---1077.4
7800--705.4--1047.6----729.6---1083.6
7900--704.6---1059.9-----737.0---1108.6
8000-691.1---1052.7----722.0---1099.8
8100--686.9---1059.4----715.0---1102.7
8200--693.1--1082.1
8300--692.1--1093.8
8400--681.4--1089.8
8500--667.8--1080.8
8600--656.8---1075.5
8200--693.1--1082.1
8300--692.1--1093.8
8400--681.4--1089.8
8500--667.8--1080.8
8200--693.1--1082.1
8300--692.1--1093.8
8400--681.4--1089.8
8500--667.8--1080.8
8200--693.1--1082.1
8300--692.1--1093.8
8400--681.4--1089.8
8500--667.8--1080.8
Pretty strong BBC, especially if it's NA and and one 4 bbl. My guess is PS style engine. If I remember correctly, that's not far from what Maskin was getting for JC in the late 90's, especially with the extended rpm with flat hp.
we aborted the test early with 1.500 length increase
it wasn't where we wanted it
next test was only 1.000" increase and
1123.7 HP and 763.4 TQ
made a few more changes to compliment runner length
kept basic 760's torque but 1153.0 hp at 8500 rpm
at 600 rpm/sec accel SF-901
on a brand new Stuska dyno with Depac tech guy there helping
same exact combo 1 day later made
1220+ hp with the way Depac guy set inertia factor
i think we had to set the inertia factor to 10 or 12 to make the Stuska correlate to SF-901
Stuska/Depac/Starr read way too high numbers like it was setup initially
physics => the racecar ran down the dragstrip "correlating" to 1153.0 hp
not like it had 1220 hp (Stuska dyno)
You have any experience with DTS dynos?
Originally posted by Z28SORR
Not only that but they also have a moving floor to simulate the under car aerodynamics.
Yes, especially with open wheel cars, a moving ground plane is critical. The kicker is that the downforce being produced sucks the "belt" away from the floor of the tunnel. Keeping it down is a major challenge, especially for a full-scale tunnel. Imagine what it takes to keep the belt down with 4000 lbs. "sucking" on it! A 40% tunnel would reduce that by many times.
The tunnel above the engine dyno probably only has the air box and top of the car with exhausts sticking up thru the floor. I'd truly like to see that run!
In PS type run, lower gears must accelerate engine maybe 2-3000 rpm/sec or more. Top gear (5th) seems to be about 3 secs max from incar cameras, and if that's 600 rpm/sec it's only 1800 rpm. If you use 9000 as shift point (probably low), that's a 7200-9000 band, so I guess a 6900 and up dyno pull makes sense. That's about 3 seconds/pull from 6900. I'm sure nobody could miss that engine running in anger, even for 3 seconds!
yes, in PS , i'd have to use my program to be sure/exact, but from memory its definetly around 3000 + Rpm/Sec in 1st gear
2.56 1st / 4.86 gears
so what happens is in 1st gear and the next gears
if actual dragstrip engine Rpm/Sec accel rate is "FASTER" than the SF-901 600 RPM/SEC test rate the engine is actually making less
than dyno shows
when dragstrip engine Rpm/Sec is slower ..the engine is putting out "MORE" HP than showed on SF901
my program displays engine Rpm/Sec rates each foot distance
with onboard data recorder , you can easily calculate Rpm/Sec accel rates, work backwards thru rest of data, and determine Torque/HP data
and the DTS dyno
theres 1 30+ miles North of me
it was Sportsman model setup ??
the inlet hose to absorber was way too small
and readings were inconsistent (cavitation and spikes)
but was later corrected with hose dia increase fix
then another DTS Pro version 100 miles east of me
works very well ...reads approx 30 to 40 HP higher than mine
but test runs mirror otherwise
than dyno shows
and the DTS dyno
That would be for full vehicle testing, which I believe is not full scale cars. Maybe by now Ferrari has a full-scale tunnel.
Another dyno that seems to work very well is the Land & Sea Dynometer
i have a good friend that has one for Jr Dragsters and GoCart racing
some people say you can't measure down to 1 or so HP accurately on engines, but the Land & Sea model he has
seems to be able to accurately measure 1/4 to 1/2 HP accuracy
i've plugged in his data into my program and it correlates very well
even correlates very well with Comet Torque-A-Verter claims of 3.25:1 Torque Multiplication
the range i come up with is 3.00:1 to 3.70:1 TQMLT
from plugging his data
he got the Jr Dragster to go 7.80's at 74.5 mph 660 Feet
with 24.0 HP @ 8200 325.0 Lbs 6.13 gear ratio 18.5*8 to 19.0*8 tires
has SF FlowBench also, but abandoned Jr Dragster efforts when officials put a LIMIT on how fast you could run with Jr Dragster
now running Go Carts at Dirt Tracks
