Camshaft gear wobble
Old Oct 6, 2003 | 08:49 PM
davepl's Avatar
I had to slightly open up the new GM cam gear to receive the snout of the cam (its not the cam, as the old gearset fits it fine).
I checked the fore-aft wobble of my new cam gear to make sure its "flat" against the snout of the cam, and its withing 0.005"
However, I've never seen a spec for how much a cam gear is allowed to "wobble". Anyone know?
Old Oct 6, 2003 | 11:34 PM
SStrokerAce's Avatar
How did you open up the gear?
.005 seems to be alot of runout, I would shoot for .001
Bret
Old Oct 7, 2003 | 01:26 AM
davepl's Avatar
Die grinder...
The stock gear had about 0.004, so I wasn't too concerned about 0.005
How did you come up with the 0.001 target?
Thanks,
Dave
Old Oct 7, 2003 | 02:06 AM
Originally posted by davepl
Die grinder...
Thanks,
Dave
You opened up the crank gear from the timing set with a die grinder?
It needs to be put on with a very tight fit, that's not a good thing.
.001 of runout is pretty high for something like that to be perpendicular. If it's more than .001 I get worried.
Bret
MadMav
May 25, 2015 09:35 PM
R@mpage
Apr 20, 2015 10:02 AM
HCz28
Jan 11, 2015 11:17 AM
1775.Z28
Jan 11, 2015 10:51 AM
