Cam ID help
Old May 2, 2008 | 08:48 PM
powerslide350's Avatar
Cam ID help
This cam was given to me.
There are no ID marks besides "3G36" on the back side.
I took it to a machine shop a family friend of ours works at.
measurments are: 1.157 width
1.503 height
height-width=.346
.346 X 1.5= .519 lift
.346 X 1.6= .5536 lift
SO how do I measure duration? LSA? I can use a micrometer and im good at calculus.
It seems like, if my measurments are correct, and if used with the 1.5 rockers, it would be a shade smaller that the hotcam, which is what I want.
Is this a bad idea altogether to use a mystery cam? Im on a budget.
The cam is in perfect shape with less that 1000 miles.
This will be going in a 93Z Stock engine with long tubes and CIA only.
Also I will be running at least a 3000 stall.
Thanks for any help. Ive posted this around other site with no feedback.
Maybe I need the advanced crew to help?
Thanks, Josh
Old May 2, 2008 | 10:09 PM
Stephen 87 IROC's Avatar
You'll need more than a micrometer. You'll need to put the cam into an engine or in a jig and use a degree wheel and a dial gauge to check duration. For LSA you'll need to know the centerline of both lobes on a cylinder.
Old May 3, 2008 | 12:12 AM
Thanks!
Old May 6, 2008 | 01:12 PM
Heres a picture of the cam. Still havnt had time to take it to a machine shop to check specs.
Can any of you tell anything from the pictures?
Old May 7, 2008 | 08:43 AM
Z-RATED94's Avatar
Its billet. Sorry, I couldn't resist. Take it to your shop of choice.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
