Cam ID help
This cam was given to me.
There are no ID marks besides "3G36" on the back side. I took it to a machine shop a family friend of ours works at. measurments are: 1.157 width 1.503 height height-width=.346 .346 X 1.5= .519 lift .346 X 1.6= .5536 lift SO how do I measure duration? LSA? I can use a micrometer and im good at calculus. It seems like, if my measurments are correct, and if used with the 1.5 rockers, it would be a shade smaller that the hotcam, which is what I want. Is this a bad idea altogether to use a mystery cam? Im on a budget. The cam is in perfect shape with less that 1000 miles. This will be going in a 93Z Stock engine with long tubes and CIA only. Also I will be running at least a 3000 stall. Thanks for any help. Ive posted this around other site with no feedback. Maybe I need the advanced crew to help? Thanks, Josh |
Originally Posted by powerslide350
(Post 5350084)
Thanks!
http://img227.imageshack.us/img227/9...e108cg1.th.jpg
Heres a picture of the cam. Still havnt had time to take it to a machine shop to check specs. Can any of you tell anything from the pictures? |
(Post 5355874)
