BOOST/NOS/COMPRESSION
Old Jul 8, 2002 | 12:32 AM
BOOST FED 95Z's Avatar
Post BOOST/NOS/COMPRESSION
I am putting togethor a 355 and im going to run around 10-12 psi boost aftercooled, and 100-150 nos. What compression pistons do I need and which pistons to go with? I have 6inch rods. This is a stock headed car with a cc306, and full exaust. Thanks for the help.
1995 MYSTIC Z28
M6
T-TOPS
CHROME Y2K VETTE WHEELS
VORTECH S-TRIM
AFTERCOOLER
CC306 CAM
1.6 RR'S
HOOKER LT'S
MUFFLEX 4"
CHASSIS ENGINEERING 8 PT.
HARWOOD 2.5" COWL HOOD
NITTO 275-40-17 DR'S
Old Jul 8, 2002 | 04:47 AM
rskrause's Avatar
Moderator
Post
You are going to have a problem with your setup. To run 10-12psi + N2O on pump gas you want a CR <9:1. The biggest dish I have seen is -21cc which will give ~9.75:1 with stock CC volume. I would get a set of -21cc pistons and pray a lot! Alternatively, only run the N2O with race gas.
Rich Krause
'95 Z-28 383 with Vortech, nitrous, etc.
"1FASTZ28"
Old Jul 8, 2002 | 08:47 AM
Jesse_Boyer's Avatar
Post
Rich, I remember seeing a -31 cc dish somewhere. If it wasn't 31, it was low 30's.
Old Jul 8, 2002 | 12:10 PM
rskrause's Avatar
Moderator
Post
<font face="Verdana, Arial" size="2">Originally posted by Jesse_Boyer:
Rich, I remember seeing a -31 cc dish somewhere. If it wasn't 31, it was low 30's.</font>
Jesse: thanks for the info. If that's the case, I say "go for it"with the caution that some pistons with alarge dish have weak crowns.
Rich Krause
"1FASTZ28"
Old Jul 8, 2002 | 09:11 PM
BluEyes's Avatar
Post
keep the quench (piston-head clearance @TDC) tight, polish the chambers and piston crowns, maybe even get a ceramic coating on the crowns. That'll help avoid detonation. (also polishing the chambers will increase cc a bit)
Lastly, having a cam with a later intake valve closing point will reduce cylinder pressures.
Old Jul 8, 2002 | 10:22 PM
Post
Thanks for the help guys. What pistons would you recommend and where to get them? A website? THanks
1995 MYSTIC Z28
M6
T-TOPS
VORTECH S-TRIM
AFTERCOOLER
CC306 CAM
1.6 RR'S
HOOKER LT'S
MUFFLEX 4"
Old Jul 9, 2002 | 06:53 AM
rskrause's Avatar
Moderator
Post
<font face="Verdana, Arial" size="2">Originally posted by BOOST FED 95Z:
</font>
http://www.jepistons.com/automotive.asp
Rich Krause
"1FASTZ28"
Old Jul 9, 2002 | 12:00 PM
Post
Anyone do a search for -31cc dish pistons? I know its been discussed before on this site. Maybe they were custom.
Old Jul 9, 2002 | 12:07 PM
rskrause's Avatar
Moderator
Post
Anyone do a search for -31cc dish pistons? I know its been discussed before on this site. Maybe they were custom.</font>
http://www.jepistons.com/pdf/2002-je4-13.pdf
Rich Krause
"1FASTZ28"
Old Jul 9, 2002 | 07:01 PM
1993lt1's Avatar
Post
21cc dish on 355 lt1 is about 9.1 to 1.21cc dish on 383 lt1 is about 9.7 to 1
Old Jul 10, 2002 | 12:05 PM
nosfed's Avatar
Post
Why are you using a 306 for that setup?
