Block Filler
Old Mar 12, 2007 | 01:03 PM
  #16
john35thss's Avatar
So it's all good then
John
Old Mar 16, 2007 | 03:52 PM
  #17
T/A lt1's Avatar
This has me interested in filling my block at least half way b/c I am rebuilding the engine and the heads are still off so whats the procedure? About how much block fill for up to the waterpump? Thanks for the info. Later
Old Mar 16, 2007 | 04:17 PM
  #18
FASTFATBOY's Avatar
If you are not boring the block, you must do the fill with the mains torqued on and torque plates on the deck.(both sides)
I would do a 1/2 fill.
I would let a machine shop do it.
David
Old Apr 16, 2007 | 08:06 PM
  #19
chrism400's Avatar
No problems here. In fact, it works so well that I plan on doing it to every
LT1 I build in the future. I use the half pour and engine and oil temps are within range all the time. I don't drive in 90 degree weather but I would suspect that things would be ok. I use a deep pan and have not seen excessive oil temps. Yet.
Old Apr 17, 2007 | 11:58 AM
  #20
00ls100's Avatar
i have a question. this block filler you speak of, would it help if I have a tiny pinhole in my block?? the pinhole caused the engine to run extremely hot. could I just fill up the pinhole with block filler?? oh it's a ls1 so aluminum block and the pinhole is located in another hole so to speak. ( the holes that are right by the pistons.) ????????
Old Apr 26, 2007 | 06:57 PM
  #21
Mikey97Z's Avatar
I'm putting together a 383 ... Do you think bolting on the heads will work the same as bolting on torque plates? I really want to rock it, but I don't have the plates.
Old Apr 26, 2007 | 08:41 PM
  #22
rskrause's Avatar
Moderator
The cylinders should also be bored when filling a block (after filling).
rich
Old Apr 26, 2007 | 09:48 PM
  #23
Mikey97Z's Avatar
rich
Really?? The HardBlok filler says it doesn't expand or contract when it hardens. Should I be skeptical of their claim?
EDIT: Yeah, I searched around and everyone (including HardBlok) recommends at least a honing after the fill.
Old Apr 26, 2007 | 10:22 PM
  #24
FASTFATBOY's Avatar
If the block has been bored:
Put the main caps on and torque them top spec
Put the heads, or torque plates on and torque them.
Fill the block
Re-hone when done with everything still in place.
I just did one as listed above, came out perfect.
The new hardblok doesn't get hot like the old hardblok did.
David
Old Apr 26, 2007 | 10:23 PM
  #25
FASTFATBOY's Avatar
If the block is aluminum, have it welded.
David
  #26
rskrause's Avatar
Moderator
I meant honed, not bored. But you can't just fill the block - it requires machining AFTER the fill.
Rich
Old Apr 26, 2007 | 10:30 PM
  #27
FASTFATBOY's Avatar
Rich
Mine didn't, was a 800 mile shortblock I bought..took it down, had it filled, honed it...perfect. No machining.
David
Old Apr 27, 2007 | 10:16 AM
  #28
AdioSS's Avatar
West South Central Moderator
honed = machining
and I hope you don't think using a hand drill hone counts...
Old Apr 27, 2007 | 10:40 AM
  #29
FASTFATBOY's Avatar
Originally Posted by AdioSS
honed = machining
Come on man, my cherry ball hone is CALIBRATED
David
Old Apr 27, 2007 | 11:31 AM
  #30
v7guy's Avatar
As has already been said...
From what i've read the procedure is to clean the block and have it checked for cracks. torque down the caps and fill it to the level you're filling it to on one side. tap it down, torque down the heads let it cure with the bank your filling level. Rotate the block so the other bank is level, tamp it down, fill it to the level, torque down the head. Take the block to get align honed, bored etc.
I read this in this forum quite some time ago but i'll be damned if I can find it now.
