Big cam stock heads cam timing
Like the title says I am installing the GM847 and 1.6rr's. I am moving to germany shortly and just don't have the time for the heads to get sent off and ported. But my Q is should I advance the cam to bring the power down in rpms to match the stock heads better or just leave it straight up. Any info is appreciated, and I know I need heads. Also on the stock bottom end with Mr. Gasket .026 HG.
Btw which heads would fit my combo best? I was thinking CNC LT4 cleaned up by lloyd or AI
Would you agree that the 847 is the same as Crane's Part Number: 109841 Grind Number: HR-296-2S-12 IG http://www.cranecams.com/?show=brows...tType=camshaft ???
If so, then it has 5° advance ground into it.
F(ast)-body
Feb 26, 2003 09:05 AM
