Anyone running 160# injecters(part 2)
Old Sep 20, 2005 | 11:01 PM
sleeperz28's Avatar
Im out of fuel again at 20lbs with 83# injecters with 80psi of fuel. Anyone running 160lb injecters? If so let me know how well they idle on gas
Old Sep 21, 2005 | 11:42 AM
rskrause's Avatar
Moderator
Re: Anyone running 160# injecters(part 2)
Yes, fine with 1,100rpm idle in a 383.
Rich
Old Sep 21, 2005 | 04:25 PM
sleeperz28's Avatar
yeah thats what I gathered from the turbo mustang guys.. Ill give them a try
Old Sep 21, 2005 | 06:55 PM
Lonnie Pavtis's Avatar
They tend to be decent with sequential fuel injection. The GN guys have run them for years with sequential.
If you have a "batch fire" or "bank to bank" (as are most aftermarket LT1 setups), they may be rather poor unless you can tolerate a very rich idle (13:1 or richer). With twice the firing pulses 83's bank to bank & 160's sequential are nearly the same.
Rich if you are referring to your car with a stock computer, it should idle quite nicely. I've had a few 383's that would go no lower than 13.7 at a 900rpm idle in bank to bank mode.
Old Sep 21, 2005 | 10:22 PM
rskrause's Avatar
Moderator
Lonnie: the idle is that high to get decent vacuum. In closed loop, it will maintain 14.7 at 800 just as well.
Rich
Old Sep 21, 2005 | 11:58 PM
sleeperz28's Avatar
Do most of you guys notice the same thing...With a batch fire you cant get the a/f above 13.8ish with out the motor bucking a bit and going lean. If I went with a seq box would that allow me to run the motor leaner such as 14.7 without the car bucking because its lean
Old Oct 16, 2005 | 01:49 PM
sleeperz28's Avatar
I tried the 160's and cant get the computer to control them with my batch fire box. The problem is its constantly going from 0-20% correction in the same cell. I try changing the surrounding cells on the map and get no luck. I didnt have any problems with this running 83# injecters. I can get the car to idle fine with a 13.5-14.0 a/f .Crusing is when I get all the problems. Has anyone got this to work with bank-bank? Im assuming most did it with SFI.
The one reason I want to keep the 160's is because I want to mix meth in with my 110 octane fuel. I dont want to spray meth, thats just one more thing to go wrong during a race. I think the car will make 1100rwhp at this point, but I want to be able to daily drive the car still.
oldschool
Feb 9, 2016 09:21 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
