4-7 swap
Old Oct 16, 2005 | 01:13 PM
shamuSS's Avatar
4-7 swap
Is this a good idea? why ? what is to be gained doing such a thing?
If i have to order a reduced base circle cam,. is it a good idea to order it with the 4-7 swap?
thanks
nick
Old Oct 16, 2005 | 05:34 PM
Stephen 87 IROC's Avatar
Re: 4-7 swap
You might see a difference on a dyno. It should make the same amount of power as an identical normal cam but it costs a lot more to buy a 4/7 swap cam. Theoretically it changes the stresses put on the crankshaft when the pistons are on the power stroke. Unless you have an 8000+ rpm race engine, you probably won't notice any difference in performance.
Old Oct 16, 2005 | 06:29 PM
jimlab's Avatar
Re: 4-7 swap
http://web.camaross.com/forums/showthread.php?t=225034
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
