anyone know approx. flow numbers for AFR227's out of the box????
Originally posted by squinn
JWINN I was just wounding what class you will be running this year?
Will you be running with the big boys in the NSCA?
I seen your car running at Ubley Dragway before and a very clean car it was indeed.
See Ya at Milan, I do believe that is where one of the NSCA events are benig held instead of Martin this year.
Originally posted by The Big Show
I don't remember personally calling you anything derogatory in my post. Most people know me to be very mild mannered and the pure ignorance you just displaced let's me know I don't even need to bother responding to your comment.
Your post however shows me where you are in this game. I don't play street racing games anymore cause 'normal adults' are suppose to think beyond the moment.
Good luck in your endeavours...with your attitude and your knowledge you will need it....
Don't worry I not going to loose sleep if you don't respond you keep right behind your computer typing as a adult making sound decisions and continue to be a genuise all nice and safe at home. I'm sure I will never have to worry about anything your building or racing because I will never see it.
Oh and please don't take this the wrong way!
Best of luck to your self.
Originally posted by RacinLT1
read up on the little chief heads before saying it isnt possible.......and of course the numbers on the page are fo heads that arent worked over....
here is a link http://www.dartheads.com/LittleChief_SChevy_HEAD_11.htm
I guess heads like this really require a -30 or so dish for pump gas(custom of course since we're talking 11* valves
). Very cool idea... but not exactly a bolt-on head or even for a standard rebuild. There are some 18* pistons that are off the shelf (I believe Weisco makes some), and 18* offset lifters are fairly common as well. I'm almost scared to ask what kind of lifters/rockers you need to run fro 11* valve train stability though. All things being equal, a 23* or even a budget 18* head is the most I'd consider for my use. I can't even imagine the money you'd have to dump in an engine to make an 11* engine worth the effort.
just curiousity. whats required to run the little chief heads 11*... even if it was an all out race car. i'm assuming a standard block is ok. custom sheet metal intake, custom headers, custom pistons for the valve angle, etc, right? not entirely sure how the valve train set up would be. any one got the details of the requirements. i remember seeing these heads assembled for around 2000-2500ish. is that realistic?
thanks,
mike
thanks,
mike
Dart
Little Chief
2 port volumes available 275cc and 315cc
Asymmetrical spread port intake ports, symmetrical exhaust ports.
11' intake valve angle. 34cc chambers. Accepts 2.25" intake valves.
Price $10500/pr complete fully ported and flowed
Little Chief
well, 10500 would be for a professionally modified head, right? i called summit and they sell the bare castings for 1300 a piece. i would guess 3900 for an assembled set ballpark. still way out there in price, but its really a pro's head for racing.
mike
mike
