any one use the stock k member with BBC
Old Mar 5, 2008 | 08:08 PM
slowride94z's Avatar
I'm in the process of installing a 430 CID aluminum head BBC in a 95, had engine had car don't have time. anyone use the stock k member with the BBC? I have a 6 cyl and a lt1 k member. Does ether have an advantage? Or what needs to be trimmed and where? have been doing searches for about 6 months some nice cars most with pictures most with aftermarket k members.
Thanks in advance Kidd
Old Mar 6, 2008 | 09:28 AM
ulakovic22's Avatar
Search on here and LS1Tech for cwaldt. He did the swap on the cheap originally using the stock k-member and then later switched to the BMR piece. I know he had to fab up brackets for it to work. Personally I just bought the BMR piece, it makes things so much easier IMO.
Old Mar 6, 2008 | 04:38 PM
yea thanks I have his sight in my favorites also
Jerry Minissales ta (CARDOMAIN)
team Patric racing Shannon z28
these are what I've been looking at
Are there any others?
cwaldt lists a bmr
daves zena
Old Mar 6, 2008 | 05:21 PM
ulakovic22's Avatar
No, Brady at Team ***** Racing and Cwaldt are the ones that probably have the most info since they have done and completed theirs. I'm about to finish mine up once I get my BS3/RacePak but that could take a month or so to save up for that kinda cash, lol.
Old Mar 16, 2008 | 10:10 AM
My 11 year old son and myself put mine in last week to see what I need to do. So far we striped the havc, and airbag, abs. trimmed the cowl but left the wiper. the engine is hanging form over head hoist I looked at the 6 cyl kmember first them put in a lt1 kmember just to look at frame mounts. I'm not going to purchase a tubular one yet, funding my new trans for the 94. I have a old set of hooker headers for 69 chevelle tried the pass side looks like a lot of interference in the frame?or side wall below the hvac.
last night I was looking on ls1tec at a ta with 496 bbc with a tubular k member the engine was very low, possibly aftermarket rack.
I will cut the 6 cyl kmember up and lower the rack as much as i can?,cut the center out lower and re plate and trim the sides. right now the rack and sides are the interference. unless I trim out some firewall and frame
ulakovic22 what did you trim or beat for header clearance with the bmr? that is still an option just $$$$ is tight always
Old Mar 16, 2008 | 10:16 AM
mdacton's Avatar
You get alot more header clearance with the k-member.
Keep everyone updayed I plan on doing this swap in the next few years.
I have seen it done on alot of cars.......the most recent was really top notch fabrication work. I will try and get some pics next time I see it. And they did not cut the cowling, its a single carb dominator and the rear touched the cowling. I know the headers were custom made, not sure about the k-member......but the valve covers are level with the shock towers if that helps at all.....
Also it has motor plates
Old Mar 23, 2008 | 11:24 AM
going to use the 6 cyl kmember for now
the center section weighed 15#
44# total 42.5# after cutting and welding
this will or should allow me to see what modifications I have to do to the firewall and side of the engine compartment. I'm dropping the rack 2" and tilting it back about 20*
where I wanted to set the engine hit the rack only
sorry for the small pictures I need another sight to host the pictures
Old Mar 23, 2008 | 12:22 PM
Old Jul 26, 2008 | 08:28 PM
bbc pictures I have found on the net could be yours
Old Jul 26, 2008 | 08:34 PM
here's some of my junk before the batteries died
the fabrication is still on going, just trying to get everything to fit
the headers are on both sides , had to rework my kmember from the previous pictures, just about where my shoe is
Old Jul 29, 2008 | 08:35 PM
lots of big pictures of bbc in fourth gen
not exactly a beauty queen , when I'm finished with the install I will tear down and repaint everything
right now I have been working on the motor mounts passenger side is easy ,the drivers side is going to have to go around the steering shaft
the headers fit perfect now no dents yet and doesn't look like I will
Ive had the kmember out and in at least 6 times
Last edited by slowride94z; Jul 29, 2008 at 08:37 PM. Reason: the date is not correct the batteries were dead 7-28-08
Old Jul 29, 2008 | 08:54 PM
ulakovic22's Avatar
That's a lot of labor, how much is your time worth?
Old Jul 30, 2008 | 06:09 PM
time at work is 65 for me but here I get to spend it with my sons and can walk off for a month or two, boy Id love to do that at work
Iv had everything except for the headers and this new intake
even have a 12 gal fuel cell and two electric pumps regulators and fuel line braided hose
everything is like 14 years old. the engine was built for a 68 camaro bbc to run nos , I bought everything then sent it to a machine shop to blueprint. a dude up the road offered me too much for the car and I bought an engagement ring end end end of racing for 13 years
my sons are old enough to help and have fun learning too
and yea IM still married
Old Mar 10, 2013 | 10:32 AM
Timberwolf's Avatar
Re: any one use the stock k member with BBC
2008 bro? yeah, it's time to get back to work!
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
1LEThumper
Jul 14, 2003 12:45 PM
