aluminum–ceramic composite connecting rods
Old Jan 29, 2004 | 12:37 PM
Rob94hawk's Avatar
Arrow aluminum–ceramic composite connecting rods
Anyone ever hear of aluminum–ceramic composite connecting rods?
I've been doing a google search on them and only have come up with one article on them:
http://www.competitionplus.com/05_14...tgen_rods.html
What brought this to my attention was they can weigh under 450 grams per rod and are much stronger than the typical aluminum rod.
If anyone has the latest Car Craft mag these rods are mentioned on page 92.
Rob
Old Jan 29, 2004 | 02:17 PM
SStrokerAce's Avatar
I've seen some light BME rods before, in the 370g range. 450g is not really that light, compared to a Eagle H beam, it is though.
Actually it sounds like the rods in that article are not a composite as much as a thick durable coating. Something along the lines of Casidiam for Ti parts but instead of being 2 - 4 microns it's 3 - 5 thou so a order of magnitude thicker. If this process works, I for one don't know if a thick coating can change the properties of aluminum enough to allow this to happen, it looks like you could run them in endurance engines where previously they were only a drag race item before. That would be cool.
With that said, for enough money you can cut the weight of a steel rod down into the low 500g mark or lower (but it costs more money) and still have enough strength do what you need to.
I do agree that cutting bobweight (piston,pin & rod mass) off the crank brings the force that is applied on the crank down dramatically and in turn is extending the life of the parts and keeping your inital crankshaft prices down or extending the useable survice life of what's in there. Because crankshafts do a have a service life the problem is the only way too tell is to cut the crank up and check it OR it will tell you by breaking on it's own.
I would think that if these parts are out there then the F1 teams would be looking at them. I know I would if I was them.
Bret
Old Jan 29, 2004 | 02:46 PM
94formulabz's Avatar
In addition, the material’s high natural lubricity provides a surface that is non-wetting, impervious to fuels, non-galling and thermally non-conductive.
Assuming the strength was there for use in an endurance engine, could the reduced heat transfer/elevated piston temperature stand in the way of their use by causing problems in the piston? I'd imagine the Rod(when compared to the rings) carries a significant amount of the heat out of the pistons. Obviously a piston coating would help this situation and anyone willing to lay out the cash for these would likely be using coatings anyways.
I'm not saying i think specifically they would or would not work because of this, just looking for other peoples thoughts on the potential significance.
-brent
Old Jan 29, 2004 | 08:02 PM
Rob94hawk's Avatar
BME?
Old Jan 29, 2004 | 08:20 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
Bill miller engineering.
Old Jan 29, 2004 | 09:11 PM
LameRandomName's Avatar
This came up in a thread on another board, having to do with titanium rods, and while everyone there was interested as well, nobody seems to know anything more.
Old Jan 29, 2004 | 09:56 PM
Rob94hawk's Avatar
Thanx Jordon. I remeber his website from quite a few years ago. Are these prices per rod?
http://bmeltd.com/rod_prices.htm
http://bmeltd.com/pistons.htm
I don't see any info on how much they weigh.
Old Jan 29, 2004 | 10:41 PM
Nope that's per set.
The applications differ and from what I remeber the rods are made to order per application. I was looking at a Ford Small Block drag racing rod.
They do some nice work on pistons for NASCAR.
Brent,
Actually the oil and block take most of the heat out of the piston. Galling and stretch and a low fatigue life is why Al rods usually suck for endurance applications.
Bret
Old Jan 30, 2004 | 02:37 AM
Brent,
Bret
Cool, didn't know if that could be significant or not which is why I asked.
-brent
Old Jan 30, 2004 | 02:50 PM
Rob94hawk's Avatar
In the Car Craft magazine they make it sound like the whole rod inside and out is aluminum–ceramic composite.
Old Jan 30, 2004 | 05:43 PM
That's what I thought too...
Journalists, Smokey Yunick used to love to play with them too because they just don't understand.
If we all read the same article then that guys rods are just coated kind of like a anodizing or a nitritding process. Something along those lines.
Bret
Devinfoote87
Feb 12, 2016 03:21 PM
Catmaigne
Jul 14, 2015 05:17 PM
ducttape1975
Jul 10, 2015 06:29 PM
mrwz28
Jul 8, 2015 09:11 PM
