AFR 227 Valvetrain Parts
Old Jan 28, 2007 | 12:09 PM
  #31
xxsaint69x's Avatar
Originally Posted by Schurters LT1
Bud...at this level of power CHEAP should not be even typed in the long run what are you saving $350-$400 total from the cheap to the best shaft mounts, is that kinda of money really worth it.....I would say NO....if you drive your car every day why not put the best parts in so it will last time after time,
i would not go for cheap if it was actually nessasry (big solidroller)...using shaft mounts with a hydrolic cam with .510 lift is kinda pointless
i found some .225 offset stud mount rockers i am thinking about using..how many do i need to get 4 or 8?
Old Jan 28, 2007 | 12:12 PM
  #32
Schurters LT1's Avatar
very true, but the AFR227 need the offset, these heads and a new cam plus the killer V-train 7000rpm = BADASS, or go AFR210's then and you will be fine with what you have, or keep the ported stock heads and just change your cam....
Old Jan 28, 2007 | 12:49 PM
  #33
engineermike's Avatar
Originally Posted by The Highlander
Subscribing to this thread to see if this is 100% necessary with the 210s.
They are not. The AFR 210's use the stock pushrod location, while the 220's and 227's move it over.
Old Jan 28, 2007 | 12:52 PM
  #34
ps. does anyone have a part number for the intake gasket that should be used with the LT4 intake?
thanks!
The large-port LT4 gasket is 12367777 and can be had from Thunder for $23 a piece.
Old Jan 28, 2007 | 01:25 PM
  #35
Highlander's Avatar
Some of my rockers are not perfectly centered.
Old Jan 28, 2007 | 01:29 PM
  #36
You have to loosen up the studs with the rockers on and adjust the guideplates side-to-side to get the tip centered. You can do this using a "crow foot" socket. It's a fairly standard procedure when setting up a valvetrain.
Old Jan 28, 2007 | 01:36 PM
  #37
xxsaint69x's Avatar
so how many offset rockers do i need? 4 right?
Old Jan 29, 2007 | 06:03 PM
  #38
xxsaint69x's Avatar
so whos has the best price on the sportsman jessel offset rockerS?
Old Jan 30, 2007 | 07:49 AM
  #39
NJLT1SS's Avatar
Call Jesel direct, and get the part number for their SS series shafts for your 227's. You can also buy direct from them, or find out who one of their vendors are. When I bought mine about 2 years ago, I paid $725 through my engine builder.
Nick
Old Feb 1, 2007 | 09:42 AM
  #40
AdioSS's Avatar
West South Central Moderator
saint69, I sent you a PM on something you should keep your eye on.
Old Feb 2, 2007 | 01:23 PM
  #41
Highlander's Avatar
Thank you and i already did that.
HectorM52
Jul 30, 2017 11:46 AM
novaiiman
May 15, 2016 11:36 AM
parkers Z28
Mar 11, 2016 08:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
