AFR 227 Valvetrain Parts
Old Jan 26, 2007 | 12:21 PM
  #16
AdioSS's Avatar
West South Central Moderator
if you're going with shaft mount rockers, you might as well take advantage of them and get a more aggressive cam. Maybe a higher ratio also?
Old Jan 26, 2007 | 05:46 PM
  #17
jimlab's Avatar
Originally Posted by xxsaint69x
what offset do i need? (.450 right)
Yes.
Do you have lifters yet? I have a set of Crower Severe-duty ultra light solid roller lifters with just a few dyno pulls on them. They have 0.180" offset on the intake for use with the AFR 215cc RR, 220cc, and 227cc heads. I'll make you a smokin' deal on them.
http://home.gci.net/~jimlab/images/Sale/PB090034.jpg
Old Jan 26, 2007 | 08:28 PM
  #18
xxsaint69x's Avatar
Originally Posted by jimlab
Yes.
hehhe, thanks for the offer man, but i am staying with my tinny CC305 cam
Old Jan 26, 2007 | 08:42 PM
  #19
jimlab's Avatar
Sorry, didn't know that all your power was coming out of a bottle.
Old Jan 27, 2007 | 11:57 AM
  #20
Highlander's Avatar
This is very interesting... although i have a 236 248 cam installed i am using 3/8 rockers with my 210s. They are not perfectly on the center on some valves, not all of them, but i am using single spring. I guess it would be nice to see how it all pans out. Subscribing to this thread to see if this is 100% necessary with the 210s.
Old Jan 27, 2007 | 12:25 PM
  #21
xxsaint69x's Avatar
eheh no bottle here All boost
Old Jan 27, 2007 | 01:45 PM
  #22
Turbo6's Avatar
Just so you know, I trashed a set of guides on my AFR 220's trying to use shaft mount rockers and a stud girdle with a solid roller. I'd HIGHLY recommend you don't make the same mistake. After it was all said and done I went to T&D shaft mounts and all is good.
Old Jan 27, 2007 | 02:02 PM
  #23
xxsaint69x's Avatar
wait? how were u using a stud gridle with shaft mounts? i guess u ment to say stud mounts? Seems like everyone is tellin me to go shaft mount which would be no brainer to me if i was using a solid roller, but i am talkin about a cam thats the size of a LT4 Hot cam
What are the cheapest Shaftmounts that will work with the heads?
Old Jan 27, 2007 | 05:21 PM
  #24
AdioSS's Avatar
why are you so stuck on running that cam?
Old Jan 28, 2007 | 09:00 AM
  #25
Schurters LT1's Avatar
You are leaving power on the table with that cam,
Old Jan 28, 2007 | 09:30 AM
  #26
AdioSS's Avatar
Exactly.
Old Jan 28, 2007 | 10:41 AM
  #27
xxsaint69x's Avatar
ya, but is very streatable and puts down awsome numbers I might call around on monday to see how much a blower cam will run. I dont want a big cam by any means, i want somethign that will drive like stock
Old Jan 28, 2007 | 10:59 AM
  #28
If you are going to go blower cam talk to Bret, and get a custom it's the same cost as off the shelf plus it will be matched to the AFR 227 heads, with the bonus of driving like stock.....I have one of his cams in my car and with 686rwhp pump gas it's all you need for your goals.....plus that set up should push 750rw when you are finished tuning
Old Jan 28, 2007 | 11:36 AM
  #29
xxsaint69x's Avatar
ill give him a call..now back to the rockers!! WHICH ONES are the cheapest part numbers and place to order wil be a great!
Old Jan 28, 2007 | 12:06 PM
  #30
Bud...at this level of power CHEAP should not be even typed in the long run what are you saving $350-$400 total from the cheap to the best shaft mounts, is that kinda of money really worth it.....I would say NO....if you drive your car every day why not put the best parts in so it will last time after time,
