Above 28".....
Old Mar 1, 2005 | 01:12 AM
mastrdrver's Avatar
Above 28".....
...what should I look for? I am thinking about using my stock heads off my 89 GT and see how good I am at this. I figure flow should continue to gain in flow. Shouldn't I be able to convert back to 28" to make sure that the numbers are still increase?
thanks
Jeremy
Old Mar 8, 2005 | 03:38 PM
MaxRaceSoftware's Avatar
Re: Above 28".....
thanks
Jeremy
if its a SuperFlow Bench then there is another small secondary Conversion Factor to apply to get a little better conversion accuracy.
the "normal Conversion Factor" is =>
Conversion Factor = ( New_FlowPress / Old_FlowPress ) ^ .5
1.133893 = ( 36" / 28" ) ^ .5
New_Flow_CFM = Old_Flow_CFM * Conversion_Factor
340.168 CFM = 300 CFM * 1.133893
for a little more accuracy you would multiply another small
Test Pressure conversion Intake or Exhaust Flow factor found in the SuperFlow Manual.
'94 Bad A Z28
Sep 11, 2003 09:34 PM
'94 Bad A Z28
Sep 11, 2003 11:22 AM
DaxsZ28
Jun 30, 2003 10:39 AM
ChrisJ325
Mar 6, 2003 02:14 PM
97TA-WS6-Con
Feb 27, 2003 08:33 PM
