90 degree elbow & single plane intakes
Old Nov 25, 2004 | 03:19 PM
  #31
SStrokerAce's Avatar
Re: 90 degree elbow & single plane intakes
Originally Posted by atljar
Bret-
You were actually able to convert the intake to lt1 head pattern?
I wanted to do it that way on mine, but there was no way i could get the runners to not be in the way of the intake bolts without really fidgiting with them to get them in there. Did you end up grinding away some of the exterior casting or...?
On mine i just bit the bullet, had the old intake bolt holes in the head welded up and driled and tapped the SBC style into them. Really wasnt the ideal way, but it works.
Yeah, I have done some by just converting the heads to a standard bolt pattern in the center of the heads.
It took me a bit to figure out how to convert the inside bolt holes and they do need some short bolts or short studs to get in there but it's 100% LT1 now.
I'll e-mail you a pic.
Bret
Old Nov 25, 2004 | 10:32 PM
  #32
biggtime's Avatar
I did this last year for my Typhoon when I put vortec heads on it and am now making one for my Blown SBC in my 442.
I used a 1" carb spacer, a 4" schedule 40 aluminum weld elbow and a camaro LS-1 TB. I welded the spacer that came with the BBK TB to the top of the elbow. Worked out really good.
The one I am making now I will use the same elbow (which I bought from Mcmaster Carr) but will probably get one of those 105mm holley TB's or a Accufab and convert the TPS to a ford one.
Here is a link to the manifold i made. Hope it helps.
http://bigtimeauto.com/albums/Typhoon/aap.jpg
Old Nov 25, 2004 | 11:11 PM
  #33
Dave69Z's Avatar
Originally Posted by SStrokerAce
That Accel Elbow doesn't look like it's going to flow gangbusters, but it's pretty low and uses a TPI/LT1 style TB.
Bret
That's exactly why I won't be using it.
Any body know if an LS1 throttlebody has the same connectors for the IAC motor and the TPS as an LT1? I found a good deal on a 90mm FAST and was considering using it instead of an Accufab.
Dave
Jun 6, 2015 08:27 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
formula218
Dec 2, 2014 04:27 PM
Elcojoe
Nov 17, 2014 10:27 PM
