85MM LS1 MAF On a LT1
Old Jul 28, 2003 | 06:01 AM
FASTFATBOY's Avatar
85MM LS1 MAF On a LT1, qll it work, It will be on a solid roller 383 and LT1 edit tuned in a dyno, Anyone tried it?
I put this post in regular tech and no one answered.
David
Old Jul 28, 2003 | 08:32 AM
kmook's Avatar
Advanced Tech Moderator
You may want to let your post be there for a little more than 9 hours before posting here saying that no one responded.
Anywho, i did a search and found this thread with this info:
Originally posted by 97FormulaWS-6
There are 2 versions availabile...
the LS1speed.com version - $150 (Last time I knew) is a direct plug and play unit.
the GM replacement Z06 part ($85) requires a cable from either Ed-Wright or Ramchargers to plug in the new MAF ($20) and either having your PCM programmed for the new MAF or programming it yourself.
rideordie
Nov 5, 2019 04:52 PM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
Jul 4, 2005 05:00 PM
