7,000 rpm's & 250 or 300 shot
Old Feb 3, 2003 | 02:53 AM
  #16
SStrokerAce's Avatar
I've seen cast steel Scats that have gone boom with only 415hp run thru them, it's ugly takes out some blocks, rods, pistons, valves.
Basically the cast Scats are strong, but when a crank goes it takes out a lot of stuff.
Bret
Old Feb 3, 2003 | 10:38 AM
  #17
Originally posted by poloz28
Not a Callies, its says hes running a Cullys steel crank, hessays nothing about forged except the pistons. and my question was how many people have heard of failures due directly to a CAST crank giving up (granted it wasnt revved to high)? no flame, just a question...
You got me there... "Cullys".... I haven't seen that name before, but a web search turned up a link to Cully bicyle pedals and cranks. I assume you mean this article from:
Summit Street & Strip Featured Vehicle
But Ed Parker has changed that. He's a respectable citizen by day, running a company that stripes asphalt parking lots in the greater Columbus, Ohio area. But on the weekends, he turns into "Fast Eddie," and tears up asphalt a quarter mile at a time in an eight-second, street-legal 1967 Camaro........
FAST SPECS
Chassis
Frame: Stock front subframe, custom 2 x 3" tube backhalf and 10-point roll cage
Front Suspension: Stock A-arm with Moroso Trick Front Springs, Koni shocks
Rear Suspension: Custom 4-link with Koni shocks, custom stabilizer bar and wheelie bars
Rear Axle: Custom 9" Ford with Moser axles, 4.11 ring and pinion
Brakes: Strange 4-wheel disc
Wheels and Tires: Weld Racing Aluma-Stars (15 x 31⁄2 front, 15 x 16 rear), Mickey Thompson ET Street (33 x 18.5-15) and Sportsman Front tires
Chassis Work: John Holt Race Cars
Engine and Transmission
Type: 632 cubic inch big block Chevy, 1,140 horsepower/960 ft.-lbs. torque
Block: Donovan 500
Reciprocating Assembly: Cullys steel crank, Scott Shafiroff 6.800" aluminum rods, Ross 14.5:1 forged pistons
Camshaft: Crane Cams solid roller, .833" lift
Cylinder Heads: Dart Big Chief aluminum, fully ported by Scott Shafiroff
Valvetrain: Jesel shaft roller rockers, Comp Cams valve springs and retainers, 2.40"/1.94" titanium valves
Induction: Custom sheetmetal intake manifold, dual 1,320 cfm Barry Grant Dominator carburetors, 350 horsepower NOS Fogger system with progressive controller
Ignition: MSD Pro Billet distributor, 7AL ignition, Blaster coil, and ignition wires
Exhaust: 21⁄4" to 23⁄8" step headers, 41⁄2" dual exhaust and Flowmaster mufflers, custom-made by John Holt Race Cars
Transmission: Powerglide with TCI manual valve body and 4,200 rpm converter.
Anyone else know "Cullys"?
Anyone think this is a cast steel crank?
Just looking over the Shafiroff website, he is a distributor for Callies, Lunati and Eagle crankshafts.
Fred
Old Feb 3, 2003 | 01:29 PM
  #18
poloz28's Avatar
yeah fred, thats the article i was talking about. i figured if he was running a forged crank, why wouldnt he specify it also, since afterall he did specify alum rods and forged pistons??? i also did a quick search, but couldnt find anything about Cully's? WTD?
Paul
Old Feb 3, 2003 | 01:44 PM
  #19
You would have to have a billet or forged crank to run a 632 cube engine. I don't know of a casting (usually high volume) that would work to make that kind of cubes. (I think a 632 uses a 4.75" stroke!)
Old Feb 3, 2003 | 05:31 PM
  #20
Mr. Horsepower's Avatar
Never heard of "Cullys" either. Could be a new manufacturer though as crankshaft machining centers are becoming more plentiful these days. Dunno but yes, it takes a 4.75 stroke.
Take care
Fastbird93
Apr 9, 2016 07:01 PM
99TransAmWS6
Mar 23, 2015 12:02 PM
super83Z
Jul 11, 2002 10:16 PM
