60lbs forged crank or 53lbs cast crank?
Old Mar 1, 2006 | 07:00 PM
  #16
Highlander's Avatar
Re: 60lbs forged crank or 53lbs cast crank?
Go with callies cranks... mine weighed at 53# racemaster... the magnum weighed 48#... but it was a 2 peice rear... couldn't use it. but it was VERY nice...
Old Mar 1, 2006 | 07:06 PM
  #17
Highlander's Avatar
Originally Posted by mastrdrver
Got an option between the two, which should I run. Will there be that much gain in the 7lbs in a motor making about 550hp? When I do run the nitrous I'm only planning on a 100 shot at the most. Looking at low 10s on motor and high 9s on the bottle. Also, would there be any concern turning a SCAT 9000 cast crank 7000rpms?
408 10.75:1 cr
Ported Canfields
Kook 1 7/8 lt headers
Turing no more then 7000 rpms
thanks
are your kooks full 1 7/8 or stepped?
Old Mar 1, 2006 | 09:15 PM
  #18
SStrokerAce's Avatar
Or go the route I go.... get the forged crank and spend the time/coin to lighten it. I've taken a stock crank down to 46lbs, you can take mass off the crank if you know what you are doing.
Either way lighter is better.... it's the same reason why a TH350 is a tenth faster at the track than a TH400. They have basically the same ratios but less mass in the smaller TH350.
LR, Dave Vizzard did a great test on all of this in a PHR article late last year. You might want to check that out.
Bret
Old Mar 1, 2006 | 09:26 PM
  #19
GreenDemon's Avatar
A forged 4340 SCAT 4" 351w crank with 3" mains.
I was under the assumption that less rotating weight would almost always equal motor hp. After doing some reading and some thinking, wouldn't it be better to have a crank that is a little heavy in a heavier car to keep the rpms up on launch at the track?
Yes, a heavier crank will give you more inertia which will help you launch. It's also why an aluminum flywheel is great for track racing, but not really that useful for a street/strip car. It all depends on the car's weight & environment.
I say forged. A few lbs. worth of crank won't make that much of a difference. W/ what you're doing I wouldn't consider the cast crank.
Old Mar 1, 2006 | 10:39 PM
  #20
mastrdrver's Avatar
Bret, do you know what month that artical was in? I know I have the magazine, just can't find it.
Highlander, the Kooks are not stepped.
Old Mar 2, 2006 | 01:45 PM
  #21
Got me but I know it was late last year. I'm thinking it was Pop Hot Rodding, but it might have been Hot Rod.
Bret
Fastbird93
Jul 11, 2015 04:37 PM
mrwz28
Jul 8, 2015 09:11 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
pimpss96
Feb 12, 2015 01:28 PM
