4.0 crank in an LT1
Old Apr 1, 2003 | 11:15 PM
chucks97ss's Avatar
4.0 crank in an LT1
I'm thinking 4.0 crank, with 5.85 rods, and a 1.15 compression height... Anybody made this happen before? What kind of clearancing did you run into? I'm mainly thinking cam clearancing... Any issues?
Chuck
Old Apr 2, 2003 | 10:52 PM
chucks97ss's Avatar
Nobody has stuffed a 4.000 in an LT1?
Later
Chuck
Old Apr 3, 2003 | 12:17 AM
Dr.Mudge's Avatar
You'd need a small base circle cam, Mark Montalvo has setup cars with big stroke before, VPREATR is his member name if I recall.
Old Apr 3, 2003 | 12:19 AM
You can buy a 409ci short block from Combination Motorsports .
Mark Montalvo has done two versions of an LT1 421ci engine, one was a 4.00 x 4.090, and the other was a 4.125 x 4.030. A search might turn up a link, or search for posts by "jimlab"... I think Mark is building his engine (not a 4.00 stroke).
Old Apr 3, 2003 | 12:48 AM
jimlab's Avatar
Actually, I think Mark's latest dyno-fresh supercharged 421 is for sale, along with the Motec engine management. It made somewhere around 1,100 horsies, if I remember correctly, and the price he mentioned was very nice.
Fred's right, Mark is the guy to talk to about big stroke LT1s.
Old Apr 3, 2003 | 07:24 AM
chucks97ss's Avatar
Well, I just needed to know that it can be done (mainly worried about the cam area).... I can handle doing all the work.
Chuck
Noer
Feb 28, 2015 11:29 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
1LEThumper
Jul 14, 2003 12:45 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
