220 protopline with HSR?
Old Oct 9, 2003 | 03:25 PM
1 DWN CAM's Avatar
I am building a boosted 406, and would like to know if the protpline 220 heads will mate to the HSR without hacking any runners? I've heard yes and no, so which is it?
Old Oct 9, 2003 | 06:18 PM
airflowdevelop's Avatar
I just did finished a miniram for a set of pro action 220's. required welding and port recontour. Knowing the HSR, I would recommend the same for best results
Dennis
Air Flow Development
Old Oct 9, 2003 | 10:36 PM
1 DWN CAM's Avatar
Really? Bummer. What is it that keeps the 220 head not work, even though it is a 23 degree head. Are the ports, just that much larger than the manifold ports, or is this a marginal difference? Also what kind of H.P. difference would I be looking at if I chose the 200cc head with like a stage 2 or 3 port?
Old Oct 9, 2003 | 11:56 PM
1racerdude's Avatar
I know that a set of protopline "235" will and can be made to fit the LT-1 or Ram Jet EFI intake.I am not familar with what a HSR is.
They will also do a bunch of carb intakes.
Old Oct 10, 2003 | 09:49 AM
1 DWN CAM's Avatar
Holley Stealth Ram. Holleys fuel injected manifold. Which is what I'd really like to stay with.
Old Oct 10, 2003 | 03:18 PM
89ProchargedROC's Avatar
<-----in total agreement with airflow development. To port it CORRECTLY to that big of a port you are going to have to weld up all the ports, port them to the head, and then mill it all flat. Its a lot of cost to do it.
Old Oct 10, 2003 | 03:22 PM
1 DWN CAM's Avatar
So the cost /to worth it ratio, proabably isn't worth it? Then maybe a heavily modified 200cc head is the way to go?
Old Oct 12, 2003 | 04:51 PM
I guess it depends on who is doing the job. I do the mini-rams /LT-X for $250. I would not think that a HSR would take much if any more time. For that kind of money I would think it would be a no brainer, if not just for the HP reason, but for the charge distribution reason. Obviously though HP gains are dependent apon application.
Dennis
tnmotown
Aug 10, 2015 11:52 PM
4586
Aug 2, 2015 01:45 PM
Catmaigne
Jul 14, 2015 05:17 PM
Nickster 7
May 1, 2015 09:04 PM
chucks97ss
Advanced Tech
157
Mar 2, 2005 06:12 PM
