2 piece crank in a 1 piece LT1
Old Jan 30, 2003 | 08:29 PM
VX355's Avatar
I know that Moroso and several others make seal adapters to make this work. I am wondering if this bolts up to a 6 speed pressure plate? I know where there are several 4340 racing cranks at good prices, but all are 2 piece . Anyway has anyone done this and if so, did you have to modify your pressure plate on your 6 speed? And did it move the pressure plate any further into the tranny or away from it. Thanks for your help
Old Jan 30, 2003 | 10:04 PM
96 Comp T/A's Avatar
The 1 piece rear main seal cranks have a register that is .020 larger diameter. There are aftermarket flywheels manufacured for the LT1 clutch setup (Street twin comes to mind as well as single disc clutch flywheel as well. There are flexplates available as well.
Old Jan 30, 2003 | 10:14 PM
FYI the Fidanza part # for the single disc LT1 style with the 2 pc crank is 198661
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Dec 4, 2014 11:56 AM
bossco
Nov 29, 2014 10:18 AM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
