**Paging Injuneer 94FormM6**
Sorry to have to put this here. I know this isn't advacnced and you're not my personal help guide, but i don't know what else to try. I tried FI and LT1 Tech and got nothing.
Here's what i got. A 93 TA with an Accel 300+ ignition, and am installing a powerdyne. I need to hook up a boost timing retard. Is there a way to wire something into this ignition (a MSD BTM, Crane TRC, etc), or do i need to buy a whole new ignition with a retard built in. The MSD Tech told me that if i had a "points input, it would wire right in."
Any help is greatly apprecitated.
Mikael,
Since MSD and Crane have products to retard timing, i hope Accel does. I would check to see if they have a product that will work with your ignition first. I personally am not a fan of mixing ignition parts from difrent mfrs.
Also your post in LT1 Tech has been there for 1/3 of a day. Give some more time, then try back here if (after a decent amount of time) you get no answers.
Thanks.
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
Thanks.
- Almost Alive: ?rwhp & ?rwtq Naturally Aspirated on the Stock Bottom End.
- Stage 3 Pro Performance Heads, Solid Roller 242/248 Cam, Endur-X Lifters,
- Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on...
tommalcolm
Sep 11, 2015 03:39 PM
