ZZ4, lt-4 hot cam users help
Old Dec 12, 2003 | 04:58 PM
350ws6's Avatar
I bought a vortec TPI base and am going to get a set of upgraded vortec castings to sit on my 1992 L-98. While the top end is off the car I want to put in a new cam. I was thinking either the ZZ4 or HOT cam. I have never driven a TPI car with a larger than stock cam and want to know the drivability issues and other experiences involved. What will my car idle at? Assuming Larger runners/TB and everything ported is teh HOT cam too big? I will be driving the car daily and racing it most weekends, I want to hit 12.9 with all the normal bolt-ons but dont want a car that won't idle and be mismatched in general.
By the way, the car has a T-56 and I will be burning a custom Prom.
So everyone with a L-98 and a big cam, what are your experiences?
These are the heads I am going to use pro topline , Does anybody have a link to better/cheaper heads?
Old Dec 13, 2003 | 07:24 AM
jzajac1's Avatar
You'll be fine with the Hot Cam, I'm running the hot cam with the Edelbrock 170cc heads and 58cc chambers and using a stock '88 corvette prom for the ecm. The idle is relatively stable and has just a little lope to it. It's a nice cam for the street/strip and the power band is spread out very nicely on it.
Old Dec 13, 2003 | 12:07 PM
350ws6's Avatar
Thanks alot for the help. Do you think the cam could also work with a SD setup for a short time until I get the Prom sorted out? Do you have any times or dynos with your car? THanks.
Old Dec 13, 2003 | 05:23 PM
jzajac1's Avatar
I couldn't tell you how it would run with SD but i'm assuming your idle may be a little erratic (low). I am using a MAF setup. With the heads,cam, 3:73 gears, edelbrock shorty headers, it runs around 13.3-13.4 in the 1/4. I recently added a holley stealth ram but don't know the results until next spring but it does pull very well with the hot cam in it, you can actually feel it in the seat of your pants.....
Old Dec 13, 2003 | 05:39 PM
'92 RS Hybrid-Z28's Avatar
The HOT cam will require a custom prom, at least it did in my son's car (91 Z28). With the ZZ4 cam and my Vortec heads the idle was fine, it didnt need much help.
jj_burchiel
Mar 5, 2015 07:05 AM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Smokn '94 Z
Aug 4, 2002 06:11 PM
Smokn '94 Z
Jul 28, 2002 02:38 AM
