ZZ4 Camshaft Combination Question
Old Apr 18, 2003 | 07:13 AM
atlasengr's Avatar
Question ZZ4 Camshaft Combination Question
I just recently got my hands on some ZZ4 aluminum heads. My 1990 Iroc-z L98 is stock internally. I want to know what is the best set of components to get for the proper power package. I want to get the ZZ4 camshaft for the setup. I need to know what distributor drive gear I need, rockers, pushrods, and timing chain. Anyone that has done this mod, please let me know the proper route to take. Thanks. Oh, and by the way, what is the best place to purchase these from???--with a good rep.
Old Apr 18, 2003 | 11:48 AM
mrr23's Avatar
i'm currently using the zz4 cam in my engine. use the stock distributor gear, need case hardened pushrods for the guideplates on the heads, rockers use any non self-aliging, and i use the comp cams 2136 timing chain.
www.fl-thirdgen.org/mrr23
has everything there i used.
Old Apr 18, 2003 | 12:38 PM
atlasengr's Avatar
Arrow mrr23
Check your PM--you got mail bud!
Old Apr 18, 2003 | 12:45 PM
mrr23's Avatar
checked and replied
Old Apr 20, 2003 | 01:25 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Since you're located in Texas I would give Scoggin Dickey a call.
http://www.sdpc2000.com/
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
HCz28
Jan 11, 2015 11:17 AM
1775.Z28
Jan 11, 2015 10:51 AM
