Wiring up a choke.
Old Aug 4, 2005 | 10:03 PM
'86 350's Avatar
Wiring up a choke.
I got a new Edelbrock perfromer carb and I need to wire up the electric choke. I know I have to ground the negative, but what should I hook the positive up to?
NOTE- I put this in the wrong forum before, which is why I posted it again here.
Old Aug 5, 2005 | 12:24 PM
dahaus's Avatar
Re: Wiring up a choke.
You need to wire it to a wire that has 12volts when the switch is on (switched hot). Make sure the wire doesn't feed anything else. It need to be a dedicated wire.
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
