wiring the TCC
Old Dec 23, 2006 | 06:40 PM
xdamagedx's Avatar
wiring the TCC
I've been reading around on the 'net here and it sounds like a bad idea to run my 85 z without the TCC working. I read that theres kits to wire-in so it will work off the brake pedal, but they all seem way overpriced ($50 for a handful of wire and blade connectors). So I was wondering if anyone could tell me which wire I need to apply the 12v to, to make the TCC turn on. I was thinking I could have a master switch (inside the car) to let it powerup or not turn on, and another to kill power when the brakes are pressed. Or is this a bad idea?
Thanks in advance
Old Dec 30, 2006 | 09:23 AM
xdamagedx's Avatar
*bump*
anyone...?
Old Dec 31, 2006 | 02:18 AM
mmmchickenboy's Avatar
B&M and TCI sell kits that activate the TCC. i bought the TCI kit (~$80) that uses manifold vacuum to determine engine load and when to energize/de-energize the TCC. the B&M kit (~$160) uses vehicle speed (and maybe manifold vacuum, i dont know, summit catalog not the detailed) to activate the TCC.
the following is a link to TCI's lock up kit instructions, i think it should answer your questions:
http://www.tciauto.com/Products/Inst...76600_inst.htm
specifically, this diagram:
Old Jan 2, 2007 | 10:55 AM
xdamagedx's Avatar
thank you
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
kandied91z
Aug 6, 2002 01:18 AM
