Wipers and Squiters Died
Old Mar 5, 2004 | 03:05 PM
Dustin Imports's Avatar
Fuse is fine. blinkers and high beams work.
any other ideas. and how to find and fix problem?
turned it on in morning to clear dew from glass and it got stuck up.
Drew
Old Mar 5, 2004 | 05:33 PM
IROC-T's Avatar
I would start with a prayer,then recheck the fuse,and make sure that the wires to the wiper is pluged in they may have come loose. If this doesn't work you didn't pray hard enough and you'll probably have to pull the wheel and replace the switch.
68camaroboltz
Oct 5, 2015 01:46 PM
Bxlt1
Sep 29, 2015 03:18 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
