Why does the radiator look this bad?
Old Jul 18, 2003 | 01:18 PM
Pro
Guest
Posts: n/a
Just curious if this is normal wear or if something was added to it to do this? I was thinking someone used tap water, or maybe stop leak.
Old Jul 18, 2003 | 07:08 PM
TheGreatJ's Avatar
Corrosion like that happens when people don't flush their coolant system every year or 2. In cold climates you're supposed to flush and fill every spring and fall...in warmer areas you can go a year or 2 between flushings.
Most people just let it ride, maybe top it off every couple months. Then they overheat and blow a head gasket because their cooling system is too clogged to be effective.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Zuvell
May 15, 2015 08:18 PM
Fatdog2
Apr 27, 2015 10:32 PM
Critter
Apr 23, 2015 09:38 PM
