where is the VATS computer located
Old Feb 23, 2003 | 04:09 PM
john-e-boy's Avatar
I have a 91 RS 305 TBI, Where is the VATS computer located??
John
Old Feb 24, 2003 | 12:20 PM
efizjb's Avatar
I just changed a complete harness on my 91 and not sure exactly where it was exactly from factory, but should be on passenger side near ECM, the Vats module has a 16 pin plug on it, I by passed mine so its not there any longer, if you ground the black with yellow trace wire where it comes out of the start enable relay on drivers side, you will bypass the vats, and energize the start enable relay.
Old Apr 26, 2003 | 05:14 AM
civic_hunter's Avatar
okay stupid question but how do you ground wires? my cusin hasnt been able to start his 91 305 camaro for two days now and im trying to help him out. thanks for any futher information.
Old Apr 26, 2003 | 01:28 PM
thezisking's Avatar
When you ground a wire, just find some bare metal thats attached to the frame. Most ground wires are black, so you could just follow a black wire and ground it where that was is....Most bolds that hold body panels on are grounds, the bracket for your alternator in a ground....The negative battery terminal is grounded (I wouldn't recommend using that though). Hope this helps.
Heathen1
Jan 2, 2016 04:27 PM
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
Lakebratt
Feb 5, 2015 07:55 PM
bsmith
Jul 19, 2002 06:08 PM
