what tranny do I have?
Old Jun 13, 2003 | 06:30 PM
  #16
TheGreatJ's Avatar
Originally posted by Nitromethane
700R4 = 4L60
4L60E = Electronic 4L60 which is a 700R4
4L80E = Electronic Overdrive of 3spd TH400
You are entirely correct.
Old Jun 13, 2003 | 10:07 PM
  #17
IZ28's Avatar
Originally posted by 91Zman
ok let me reword what I said for you to understand.. 700R4 were renamed 4L60s for 90-92..same animal
You are completly incorrect dude. No Third Gen ever had an electronically shifted 700R4. (a 4L60E) They all have TV cables and no extra computer for the trans. As a matter of fact even the 1st year 93 4th Gen had a 700R4 and the 94's-on used the 4L60E instead.
Old Jun 13, 2003 | 11:46 PM
  #18
Nitromethane's Avatar
AGH! He is NOT incorrect, 4L60 and 4L60E are 2 seperate transmissions. 4L60 is the SAME as a 700R4, a 4L60E... see that E on the end? Thats the electronic 4L60/700R4 - example - a 1991 Corvette came with a 4L60 - a 1996 Corvette came with a 4L60E.
Old Jun 14, 2003 | 12:12 AM
  #19
IZ28's Avatar
**** **** **** ****, I can't believe I confused that. Well at least my info was correct, if that was what we happened to be discussing. And yes in the later years all they did was change the name with no differences.
Old Jun 14, 2003 | 12:14 AM
  #20
Thankyou!
Old Jun 14, 2003 | 09:42 PM
  #21
91Zman's Avatar
nanner nanner naaaaaneerrrrrr
Old Jun 14, 2003 | 09:45 PM
  #22
91Zman's Avatar
Angry
Thankyou!
and thank you sir!
Old Jun 15, 2003 | 06:49 AM
  #23
IZ28's Avatar
Old Jun 15, 2003 | 04:40 PM
  #24
Slow91z's Avatar
I would go with a 26,000 GVW, or at least a 20,000 depending on what size u want it to be - there is no "fit" for tranny coolers, you simply need to run the hoses from the tranny lines and wire tie the tranny cooler to the X brace in front of the radiator behind the bumper cover - im sure some people can give you mounting tips, but most people just wire tie it onto the X Brace, you don't see it anyway.
Some people use the radiator's internal transmission cooler and add a seperate cooler just to help the radiator out - but by completely bypassing the radiator, you're removing all the transmission heat from the engine coolant so reducing both transmission and coolan temps - n face it, in a 3rd gen, the coolant can stand to lose around 40 degrees
NONONONONONONO never unhook the Tranny from the radiator....you will only HURT tranny cooling this way....use both a external cooler and the radiator and a deep pan is a great idea....the more fluid you have in the system the better, and it's harder to burn it this way....the aluminum tranny pans with cooling fins are also a great idea because they do double duty....I would still use a tranny cooler first though
Old Jun 15, 2003 | 06:10 PM
  #25
TheGreatJ's Avatar
Umm....if you use a decent size fluid-to-air cooler then it's much more effective than the "fluid-to-200* engine coolant" factory setup. The factory rig has much less cooling capacity because the cooling medium itself is very hot. It's like working out and then trying to cool off by showering in boiling water.
You do have to use a good-size fuild-to-air cooler though, or it won't cool the fluid enough due to lack of surface area.
Old Jun 16, 2003 | 04:54 PM
  #26
Slow91z's Avatar
Ok I'll agree that if it has enough surface area then that's true....but if the fluid goes through the radiator and cools some....THEN goes through the aux. cooler after it's at the lower temp from the Radiator, then the Aux cooler can cool it even more....instead of just getting the cooling capability of the Aux. cooler you get both....but if the fluid goes through the cooler then the radiator you're working against yourself
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
